Installation on Windows
- Published: Thursday, 09 May 2013 06:06
- Hits: 63198
WARNING 1: On Windows 7 -11.x OS, you must install this software as user with administrator privileges.
This user name must have only English letters and without spaces.
WARNING 2: Only for the first time of CodeTyphon installation in your Computer, you must install some System Libraries.
1. Step : Download
Download CodeTyphonIns.zip
to any drive.
Extract CodeTyphonIns.zip all content (extract here).
2. Step : Install
Go to new CodeTyphonIns directory and run install.bat "as Administrator"
Give zero "0" to Install CodeTyphon Studio
3. Step : Setup and Build
From "Setup Script" Select option (0) "Install System Libraries", to install
DirectX End-User Runtimes package.
WARNING: You must install DirectX End-User Runtimes package,
in order to compile CodeTyphon BigIDE, even if you do not plan to use DirectX components in your projects.
You can install the latest MS DirectX End-User Runtimes manual,
with web installer from here
(2-15 minutes procedure)
From "Setup Script"
(10-30 minutes procedure)
NOTE:
On all Windows 64Bits CodeTyphon has Multi-Architecture ability,
so you can run both 32bit and 64bit Typhon IDE.
