Quick Installation Procedure
- Published: Tuesday, 30 April 2013 17:45
- Hits: 26689
Download => Unzip => Install => Build ALL
1) Download CodeTyphonIns.zip from our web site (or from any mirror server).
2) Install CodeTyphon
a) On MS Windows: unzip to any directory/drive and run install.bat as administrator
or
- open an administrator CMD window and execute
install.bat
b) On Unix OSes:
- Give passwordless "sudo" root privileges to installation user.
- unzip to your /home directory and run install.sh, as "normal" user with "sudo" root privileges.
- open a terminal execute
3) From "Install Script" select option number (0) "Install CodeTyphon Studio" .
4) From "Setup Script" select option number (0) "Install System Libraries" , only the first time of CT installation.
5) From "Setup Script" select option number (8) "Remove and Build ALL" to Build ALL from sources .
6) Run Typhon IDE and start programming...
WARNING: For MS Windows, you must install this software as user with administrator privileges .
WARNING: For Linux, FreeBSD, NetBSD, OpenBSD, NetBSD, DragonFly, Solaris, OpenIndiana and MacOS this installation
requires sudo root privileges.
