Pascal - Loops
- Category: Chapter 2
- Published: Sunday, 14 April 2013 14:28
- Hits: 21175
There may be a situation when you need to execute a block of code several number of times. In general statements are executed sequentially: The first statement in a function is executed first, followed by the second, and so on.
Programming languages provide various control structures that allow for more complicated execution paths.
A loop statement allows us to execute a statement or group of statements multiple times and following is the general from of a loop statement in most of the programming languages:
Pascal programming language provides the following types of loop constructs to handle looping requirements. Click the following links to check their detail.
| Loop Type | Description |
| while-do loop | Repeats a statement or group of statements while a given condition is true. It tests the condition before executing the loop body. |
| for-do loop | Execute a sequence of statements multiple times and abbreviates the code that manages the loop variable. |
| repeat-until loop | Like a while statement, except that it tests the condition at the end of the loop body. |
| nested loops | You can use one or more loop inside any another while, for or repeat until loop. |
1. Loop Control Statements:
Loop control statements change execution from its normal sequence. When execution leaves a scope, all automatic objects that were created in that scope are destroyed.
Pascal supports the following control statements. Click the following links to check their detail.
| Control Statement | Description |
| break statement | Terminates the loop or case statement and transfers execution to the statement immediately following the loop or case statement. |
| continue statement | Causes the loop to skip the remainder of its body and immediately retest its condition prior to reiterating. |
| goto statement | Transfers control to the labeled statement. Though it is not advised to use goto statement in your program. |
