Curl not enabled 6 years 10 months ago #14018
  • Theo Kamphuis
  • Theo Kamphuis's Avatar Topic Author
I try to install OrangeHRM server, but the installation stops saying Curl not working. I tried to edit the php_production.ini to make curl available, but no luck.
Last edit: by Theo Kamphuis.
Curl not enabled 6 years 10 months ago #14019
UWS PHP has many modules, we disable many of them (NOT common use) for speed...
a) Close ALL Servers
b) Go to PHP=>Edit Basic and Modules=>PHP Modules Enable/Disable
c) and Check php_curl.dll
d) Start Servers again
Curl not enabled 6 years 10 months ago #14022
  • Theo Kamphuis
Excelent, all is ok now. Thanks a lot for your quick answer.
Curl not enabled 6 years 10 months ago #14023
Have fun Sir
