- Thank you received: 0
Ultra Web Server Elements discussions and problems.
Question Issues on MySQL 8.0
- Henry
- Topic Author
- Offline
- Fresh Boarder
Less
1 month 1 day ago - 1 month 1 day ago #13021
by Henry
Issues on MySQL 8.0 was created by Henry
During the usage of MySQL 8.0 Element, i found the following issues and a way to bypass them, at least until the development team include a proper solution.
Issue #1: when starting MySQL 8.0, an error message saying that file ssleay32.dll is missing.
Analysis: the file is not included in .7z file provided by developers, so it's needed to retrieve it from the original MySQL "noinstall" zip file
Solution: download the "Windows (x86, 64-bit), ZIP Archive" (currently v8.0.13) from https://dev.mysql.com/downloads/mysql/ and in zip file go to "\mysql-8.0.13-winx64\bin" folder and copy the missing ssleay32.dll file to the "UltraWebServer\core\mysql80\bin" folder
Issue #2: password change/reset for root@localhost fails from interface. the same applies also for user pma@localhost (needed in phpMyAdmin)
Analysis: MySQL 8.x has changed the user password change/reset procedure from previous v5.x
Solution: manual change of password ('root' by default) by creating a text file with the following SQL instructions:
and save it to any path with any name (i saved mine it to C:\\UltraWebServer\htpasswd\mysql\mysql8changepw.txt)
Then keep the MySQL in stopped state and open a command (DOS) window, then go to your UltraWebServer\core\mysql80\bin\folder and run the command:This will read the SQL statements from previously saved text file and change the password for both users root@localhost and pma@localhost from "root" to "MyNewPassword", showing the execution results in the command (DOS) window.
Hope this help.
FLUSH PRIVILEGES;
ALTER USER 'root'@'127.0.0.1' IDENTIFIED BY 'MyNewPassword';
ALTER USER 'pma'@'127.0.0.1' IDENTIFIED BY 'MyNewPassword';
mysqld --init-file=C:\\UltraWebServer\htpasswd\mysql\mysql8changepw.txt --console
Hope this help.
Last edit: 1 month 1 day ago by Henry.
- Sternas Stefanos
- Away
- Moderator
- Ex Pilot, M.Sc, Ph.D
1 month 1 day ago #13022
by Sternas Stefanos
CodeTyphon and UWS, Architect and Programmer
Replied by Sternas Stefanos on topic Issues on MySQL 8.0
We fix Issue 1
We working on Issue 2
Again, your help is critical for us
We fix Issue 1
