Missing Font "Arial" CT 6.8 6 years 10 months ago #13815
  • Jose Ceravolo
  • Jose Ceravolo's Avatar Topic Author
Hi All,
After trying to make this work for days I found out the component I was using maybe wasn't the right one.
So I switched it to tfpjsonReport now I can preview the report in design time, during runtime it gives me that message.
I am attaching the source code.
fprPersonListing.LoadFromFile(ExtractFilePath(ParamStr(0)) + '\Reports\PersonListing.json');
fprPersonListing.RunReport;
fprPersonListing.RenderReport(fprPreview);
Thanks in advance,
Jose.
Missing Font "Arial" CT 6.8 6 years 10 months ago #13817
  • Jose Ceravolo
If that helps I am using Windows 10 and the Arial font is not missing.
Any ideas?
I don't want to give up on CT, but I am getting to the point where it's too much time wasted.
Missing Font "Arial" CT 6.8 6 years 10 months ago #13818
  • Thank you received: 1138
please, your attach file ?
only the source, please.
Did you try and CT 6.9 ?
Missing Font "Arial" CT 6.8 6 years 9 months ago #13819
  • Jose Ceravolo
I will install CT 6.9 and try then.
Then, if it does not work. I'll post the source here.
Thanks.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13820
  • Jose Ceravolo
CT 6.9, same error.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13821
Try this
go to
C:\codetyphon\CodeOcean\pl_FontEngine\samples\xmedia\
and copy arial.ttf to your app folder
Missing Font "Arial" CT 6.8 6 years 9 months ago #13823
  • Jose Ceravolo
Putting Arial.ttf in the project folder does not help.
I spent a couple of days digging.
In the FPReport source code I found out that for some reason this is not working:
lFC := gTTFontCache.FindFont(Font.Name); ===>>>> Font.Name in this case is 'Arial'
if not Assigned(lFC) then ====>>>> IFC is nil here, so the above line does not return the font object
raise EReportFontNotFound.CreateFmt(SErrFontNotFound, [Font.Name]);
This is a problem with the code in fpTTF that might be related with Windows 10. I wonder if there's an update to this function.
This is located in: \codetyphon\fpc\fpc64\units\x86_64-win64\fcl-pdf
Unfortunately I can't keep digging.
Thanks,
Jose.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13824
Missing Font "Arial" CT 6.8 6 years 9 months ago #13825
  • Jose Ceravolo
I created a program to get the list of fonts in the fpTTF class.
That should help since all fonts are listed there, but still fpReport can't fint it on the list.
I hope this helps, I am still a noobie here.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13826
I think we found the problem
please, go to
C:\codetyphon\typhon\components\lz_FpReport\source\base\fpreportpdfexport.pp
replace line 126
fnt := gTTFontCache.Find(AFontName); // we are doing a PostScript Name lookup (it contains Bold, Italic info)
with
fnt := gTTFontCache.FindFont(AFontName); //=== ct9999 ======
and the same...
C:\codetyphon\typhon\components\lz_FpReport\source\base\fpreportfpimageexport.pp
replace line 199
with
Missing Font "Arial" CT 6.8 6 years 9 months ago #13827
  • Jose Ceravolo
Same error, I am getting the error on fpreport.pp.
I am attaching the images.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13828
1) Put fixes above in FpReport source.
2) copy C:\codetyphon\CodeOcean\pl_FontEngine\samples\xmedia\arial.ttf
to your FpReport font folder
We get the same with error with you, without arial.ttf
with arial.ttf in FpReport font folder, ALL OK
The above CodeOcean sample project is:
C:\codetyphon\CodeOcean\lz_FpReport\samples\demos\fcldemo.ctpr
Missing Font "Arial" CT 6.8 6 years 9 months ago #13829
  • Jose Ceravolo
I still get the same error.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13830
  • Jose Ceravolo
I tried running that project,. fcldemo, but nothing happens.
It compiles, but that's it.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13831
It's NOT GUI app.
Look at fcldemo.ctpr out directory
C:\codetyphon\CodeOcean\lz_FpReport\samples\xbin\
fcldemo app build fpreportdemo-grouping2.pdf
Missing Font "Arial" CT 6.8 6 years 9 months ago #13832
  • Jose Ceravolo
Yes, the report is there.
It's a wonder why it does not work in an application.
Folder issues maybe?
Missing Font "Arial" CT 6.8 6 years 9 months ago #13834
Maybe,
without your app full source we can't give you more help
FpReport it's a new package and maybe has problems.
We try to fix all problems but .... :huh:
Missing Font "Arial" CT 6.8 6 years 9 months ago #13838
  • Jose Ceravolo
I used the Address Book sample to duplicate the problem.
I am attaching the whole project.
Missing Font "Arial" CT 6.8 6 years 9 months ago #13839
A) Solution A
-First of All
make a folder "fonts" into your addrbook app
copy to new "fonts" folder arial.ttf from CodeOcean Samples
-In Report1.json Line 89 replace "Arial-BoldMT" with "Arial"
-In your main app unit frmmain
add to uses fpTTF unit
uses
  SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, DB, Dbf, Grids, DBGrids, DBCtrls, ExtCtrls, ActnList, Menus,
  StdCtrls, Buttons, fpjsonreport, fpreportdb, fpreportformexport,
  fpTTF,    //<<<<==== ct9999 ====
  FPReport;
and 2 lines at
procedure TMainForm.btPrintClick(Sender: TObject);
  gTTFontCache.SearchPath.Add('fonts/'); //<<<== ct9999 ==============
  gTTFontCache.BuildFontCache;              //<<<== ct9999 ==============
  FPJSONReport1.LoadFromFile(ExtractFilePath(ParamStr(0)) + 'Report1.json');
  FPJSONReport1.RunReport;
  FPJSONReport1.RenderReport(FPExport);
gTTFontCache is Variable in fpTTF.pp
I think now you can continue by your self... :)
Missing Font "Arial" CT 6.8 6 years 9 months ago #13840
  • Jose Ceravolo
Excellent!!!
I changed it a bit.
I added LCLIntf to the uses clause and changed the lines to update the font cache to:
gTTFontCache.SearchPath.Add(GetEnvironmentVariable('WINDIR') + '\Fonts\');
This way all fonts in windows work.
Thanks for your help!
