CT LAB ver 6.90 7 years 2 months ago #13640
  • Peter Heckert
  • Peter Heckert's Avatar
I use Typhon 6.9 r61718 FPC 3.3.1 x86_64-win64-win32/win64 (on Win10 64 bit)
I can cross-build a 32 bit target without errors and an .exe file is generated.
When I start the exe from the IDE or directly without IDE, it doesnt run, it immediately terminates without any error messages.
It happens with console and with GUI programs and always.
If I set a breakpoint in the code, it is not hit.
So I think, there is a problem with the startup code.
If I build the same code with the Typhon 32 IDE, there are no problems.
Otherwise I like this new LAB version, thanks for your work!
Last edit: by Peter Heckert.
CT LAB ver 6.90 7 years 2 months ago #13642
On Win64 ct-FPC64 has some problems with cross-build for Win32 targets,
but working OK with NO Win 32bits, arm, aarch64 and 64bits cross-build Target.
Original FPC64 on Win64 has a lot of cross-build problems and with 64bits targets.
We try to fix these on Win64 cross-build to Win32 problems...
it's NOT so simple info1 info2
The following user(s) said Thank You: Peter Heckert
CT LAB ver 6.90 7 years 2 months ago #13643
  • Peter Heckert
Now I install 64 bit crossbuild for the 32 bit IDE.
Is this recommended? (I try it anyway ;-) )
Or, is it possible to instruct the 64 bit IDE to use the 32 bit compiler?
CT LAB ver 6.90 7 years 2 months ago #13644
Yes, if you build FPC32 compiler
CTCenter => Compiler => "FPC32 Build ALL"
But It's better to use Typhon32 IDE for Win32 app
just open CTCenter =>Typhon IDE => "Typhon 32, Build BigIDE"
CodeTyphon Support MultiArch Technology on MS-Windows 64,
Typhon32 and Typhon64 on the same OS without any problem.
CT LAB ver 6.90 7 years 1 month ago #13667
  • Thank you received: 231
We release CodeTyphon version 6.90 Final
CT LAB ver 6.90 7 years 1 month ago #13668
  • gulyone
  • gulyone's Avatar
  • Thank you received: 6
Ok
I uninstalled completely 6.80, then i tried to install 6.90
32 bits ide all went fine but the bat file stopped its execution; so i openend CT center and asked to build 64bits ide
after a while the pipelined dos box flooded with exceptions and mem faults so i needed to RESET (LOL?!) my computer gone crazy
any clue?
windows 7 service pack 1 well updated/maintained 64 bits version
regards
I am back with 6.80 for now :-P
Last edit: by gulyone.
CT LAB ver 6.90 7 years 1 month ago #13669
Did you have antivirus active in CT folder ?
Your RAM size ?
CT LAB ver 6.90 7 years 1 month ago #13670
  • gulyone
  • gulyone's Avatar
ram 8Go, avirus is avast with exceptiion on ct folders
CT LAB ver 6.90 7 years 1 month ago #13671
Sir,
we test (again) CT 6.9 to Win7-64 with the latest OS updates
without problem
Please check your PC
CT LAB ver 6.90 7 years 1 month ago #13672
  • Vbxler
  • Vbxler's Avatar
  • Thank you received: 5
On my win7 64bit computer with 16BG RAM,
CT6.90 I get many error messages.
When I open an existing project I get the following messages:
[Content]
Kann die Komponentenklasse "TLSTimeEdit" nicht finden.
Kann die Komponentenklasse "TAbZipper" nicht finden.
Kann die Komponentenklasse "TUniqueInstance" nicht finden.
Warning:
The project uses the following design time packages which might be needed to open the form in the designer.
If you continue, you might get errors about missing components and the form loading will probably create very unpleasant results.
It is recommended to cancel and install these packages first.
Unit allluicontrolsregister in Package pl_luicontrols 6.9.2
Unit ZComponentReg in Package pl_zeosdbo 6.9.2
Unit AllSolutionsReg in Package pl_solutions 6.9.1
Unit AllSolutionsRegIDE in Package pl_solutions 6.9.1
Unit allAbbreviaReg in Package pl_abbrevia 6.9.1
After installing the package codetyphon reboots but the messages come again.
On a computer with Linux Xubuntu 18.04 there are no problems, only a few buttons in the design view are strange.
Tomorrow I'll recompile CT in the office,
maybe there was a warning that did not pay attention.
CT LAB ver 6.90 7 years 1 month ago #13674
  • gulyone
  • gulyone's Avatar
problem solved for me :
in fact, even with exceptions set around folders, avast avirus came out of nonsense, SO i disabled it while building CT 6.90 and all went fine
CT LAB ver 6.90 7 years 1 month ago #13675
  • gulyone
  • gulyone's Avatar
hem win 32bits ide is chiped with 46 components pages while 64bits ide contains 164 components pages? is this new standard behavior? nevermind i'll install packages upon my needs, i guess
thanks
CT LAB ver 6.90 7 years 1 month ago #13676
Yes
this is the standard behavior for ALL
32bit OSes.
To prevent Typhon32, Out of Memory Building Problem
Now Typhon32 need only 1Gbyte RAM to build.
CT LAB ver 6.90 7 years 1 month ago #13679
  • Vbxler
  • Vbxler's Avatar
Today I cleaned up again everything and
built a big IDE with CTC and everything
seems to work well.
Thanks for the new version!
Vbxler
CT LAB ver 6.90 7 years 1 month ago #13682
have fun
CT LAB ver 6.90 7 years 1 month ago #13695
  • fredvs
  • fredvs's Avatar
Hello Sternas.
> You must post at FreePascal team mail-list,
OK, I did it:
free-pascal-general.1045716.n5.nabble.co...42375-td5734232.html
But no lot of help + answers there after last post. :(
So if you have a idea how to fix it, I vote for it.
CT LAB ver 6.90 7 years 1 month ago #13697
We are working on this,
please give us time...
The first approach mseide-msegui Lib as CT package,
80% it's OK with some modifications.
CT LAB ver 6.90 7 years 1 month ago #13698
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
Another really big problem with CT 6.90 Release is 'GetOrCreateWidgetInfo: MainWidget info was created causing a memory leak.':
www.mail-archive.com/lazarus@lists.lazar...de.org/msg08218.html
The error occures in my project in customform.inc:
procedure TCustomForm.Show on modal form;
  if Application.Scaled and Scaled and (Monitor.PixelsPerInch<>PixelsPerInch) then
    AutoAdjustLayout(lapAutoAdjustForDPI, PixelsPerInch, Monitor.PixelsPerInch,
      Width, MulDiv(Width, Monitor.PixelsPerInch, PixelsPerInch));
  Visible := True; // Here the error is shown
  BringToFront;
There is also some problems with ZEOS witch was already in 6.80 and in the Lab 6.90:
zeoslib.sourceforge.net/viewtopic.php?f=...146&p=128788#p128788
Because of the first error 6.90 is not useable for me.
6.80 is OK so far, but only when I use ZEOS from 6.70
CT LAB ver 6.90 7 years 1 month ago #13699
one question before anything else
from uvviewsoft.com/cudatext/
CudaText is a cross-platform text editor, written in Lazarus.
Is this correct ?
CT LAB ver 6.90 7 years 1 month ago #13700
  • fredvs
  • fredvs's Avatar
Hello Sternas.
Wow, I am very excited to see this.
Absolutely no worry, the excellent news is that msegui is not forgotten.
About the compatibility with fpc >= 3.3.1 rev 42375, I have to confess that, even with the explanation of Sven, I did not catch how to fix it.
Last edit: by fredvs.
