arm-linux raspberry pi 11 years 8 months ago #4422
  • zeljko
  • Thank you received: 38
Win xp CodeTyphon 4.4 32
for raspberry pi
How do I set compiler to linux-arm
install to
Cross element for arm-linux
1. New project
2. Project -> Project Options -> Code Generation
Target OS (-T): Linux
Target CPU family (-P): arm
(ok)
3. Run -> Build
error:
Options changed, recompiling clean with -B
project1.lpr(22) Warning: "crti.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: "crtbegin.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: "crtend.o" not found, this will probably cause a linking failure
project1.lpr(22) Warning: "crtn.o" not found, this will probably cause a linking failure
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: cannot find -ldl
project1.lpr(22) Error: Error while linking
project1.lpr(22) Fatal: There were 1 errors compiling module, stopping
How do I set: Code Typhon compile application for arm debian raspberry pi?
arm-linux raspberry pi 11 years 8 months ago #4434
  • zeljko
According to instructions raspberry pi WORK!:
www.pilotlogic.com/sitejoom/index.php/fo...iling-arm-linux#4050
For arm-linux Raspbian
download this Cross Library files Sir
www.pilotlogic.com/codetyphon/crosslibraries/arm-linux-pi.7z
We will release all Cross Target OS Libraries files soon...
Thanks sternas!
arm-linux raspberry pi 11 years 8 months ago #4435
  • Thank you received: 1121
have fun
arm-linux raspberry pi 11 years 8 months ago #4458
  • zeljko
compile project to typhon64 locate arm-linux-pi (qemu emulator work)
copy project1 to board beaglebone black error:
Failed to execute child process "/home/debian/razvoj/project1"
(No such file or directory)
Lazarus board beaglebone black work
how to do the:
arm-linux-
beaglebone black
I have a board beaglebone black
what should copy
thanks
Last edit: by zeljko.
arm-linux raspberry pi 11 years 8 months ago #4459
  • FredyCC
  • FredyCC's Avatar
  • Database/Developer
  • Thank you received: 10
I think what you're trying to do is run the same executable created from a raspberry to beaglebone black and therefore does not run.
Basically what I do is copy all the libraries of the raspberry (.so) and paste to a linux distribution and through CodeTyhon x86 compile for ARM specifying the path to the libraries.
Theoretically the same processs should work for beaglebone black depending on the distribution you have installed.
Are you using Angstrom?
Last edit: by FredyCC.
arm-linux raspberry pi 11 years 8 months ago #4460
  • zeljko
arm-linux raspberry pi 11 years 8 months ago #4461
  • zeljko
qemu emulator work: debian_squeeze_armel_desktop.qcow2
(armel)
beaglebone black not work: debian-wheezy-7.0.0-armhf-3.8.13-bone20.img
(armhf)
install lazarus beaglebone black, lazarus work
arm-linux raspberry pi 10 years 8 months ago #5874
  • zeljko
CodeTyphon 4.9
Debian 7 64 LXDE
not copmpile arm linux
library arm-linux-pi
Compile Project: Exit code 256, Errors:1
/usr/lib/codetyphon/fpc/bin/x86_64-linux/arm-linux-ld: warning: link.res contains output sections; did you forget -T?
/usr/lib/x86_64-linux-gnu/crti.o: file not recognized: File format not recognized
project1.lpr(22,0) Error: Error while linking
help!
arm-linux raspberry pi 10 years 8 months ago #5875
Sir, did you download Linux-arm libraries ?
arm-linux raspberry pi 10 years 8 months ago #5876
  • zeljko
No library arm-Linux or Linux-arm
please target
arm-linux raspberry pi 10 years 8 months ago #5877
Sir, please
1) download arm-linux-pi libraries from our server info
2) Setup your Project Libraries to this folder
arm-linux raspberry pi 10 years 8 months ago #5878
  • zeljko
yes download library arm-linux-pi
work to
CodeTyphon 4.4
www.pilotlogic.com/sitejoom/index.php/fo...m-linux-raspberry-pi
not work
CodeTyphon 4.9
arm-linux raspberry pi 10 years 8 months ago #5879
thanks Sir
tomorrow we will check this and I will report here
arm-linux raspberry pi 10 years 8 months ago #5890
  • zeljko
uninstal and install CT 4.92
upgrade to CT 5.0
Use QT4
install system libraries
remove and buidl Typhon
FPC64 build cross element All
arm linux not work
Help!
arm-linux raspberry pi 10 years 8 months ago #5892
Please Sir,
try to use Typhon32 and FPC32
arm-linux raspberry pi 10 years 8 months ago #5899
  • zeljko
not install library
HELP SET: /etc/apt/sources.list
(deb .....)
debian 7 64 LXDE
   CodeTyphon Try to Fix Links for SysLibraries
[INFO] Libraries Directory: /usr/lib/x86_64-linux-gnu
   [ OK ] /usr/bin/qmake-qt4 Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libc.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libdl.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libpthread.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libX11.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgobject-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libglib-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgthread-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libpango-1.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libcairo.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libatk-1.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libXtst.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libGL.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libGLU.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libfreetype.so Exists
   [ OK ] /usr/lib/x86_64-linux-gnu/libXxf86vm.so Exists
   [ERROR] /usr/lib/x86_64-linux-gnu/libgtkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgtkglext-x11-1.0.so
   [ERROR] /usr/lib/x86_64-linux-gnu/libgdkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgdkglext-x11-1.0.so
   [ OK ] /usr/lib/x86_64-linux-gnu/libz.so Exists
[INFO] Libraries Directory: /usr/lib/i386-linux-gnu
   [ERROR] /usr/lib/i386-linux-gnu/libc.so.6 NOT Exists ???, can't make symlink for: libc.so
   [ERROR] /usr/lib/i386-linux-gnu/libdl.so.0 NOT Exists ???, can't make symlink for: libdl.so
   [ERROR] /usr/lib/i386-linux-gnu/libpthread.so.6 NOT Exists ???, can't make symlink for: libpthread.so
   [ OK ] /usr/lib/i386-linux-gnu/libX11.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libgobject-2.0.so Exists
   [ERROR] /usr/lib/i386-linux-gnu/libglib-2.0.so.0 NOT Exists ???, can't make symlink for: libglib-2.0.so
   [ OK ] /usr/lib/i386-linux-gnu/libgthread-2.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libgmodule-2.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libpango-1.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libcairo.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libatk-1.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libXtst.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libpangocairo-1.0.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libGL.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libGLU.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libfreetype.so Exists
   [ OK ] /usr/lib/i386-linux-gnu/libXxf86vm.so Exists
   [ERROR] /usr/lib/i386-linux-gnu/libgtkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgtkglext-x11-1.0.so
   [ERROR] /usr/lib/i386-linux-gnu/libgdkglext-x11-1.0.so.0 NOT Exists ???, can't make symlink for: libgdkglext-x11-1.0.so
   [ERROR] /usr/lib/i386-linux-gnu/libz.so.1 NOT Exists ???, can't make symlink for: libz.so
CodeTyphon Fix Links for SysLibraries
Finish !!!
arm-linux raspberry pi 10 years 8 months ago #5900
Sir this is NOT a problem
Debian has libgdkglext-x11 in other directory
Try to "Build ALL"
arm-linux raspberry pi 10 years 8 months ago #5901
  • zeljko
Remove and Build ALL
Not compile Typhon 32
Start Action at 3-9-14 13:00:33
          Build Typhon32 Small IDE for Linux
       Clean Typhon64 IDE Setings
       Clean Typhon32 IDE Setings
[INFO] Clean Typhon IDE Setings finish
   Restore Typhon64 Default IDE Setings
   Restore Typhon32 Default IDE Setings
[INFO] Restore Typhon Settings finish
make -C packager/registration
make[1]: Entering directory '/usr/lib/codetyphon/typhon/packager/registration'
/bin/rm -f ../units/i386-linux/fcllaz.ppu
/usr/lib/codetyphon/fpc/bin/i386-linux/ppc386 -MObjFPC -Scghi -O1 -g -gl -vewnhi -l -Fu. -Fu../../../fpcsrc/rtl -FE. -FU../units/i386-linux -g- -dUSE_QT_45 -di386 fcllaz.pas
Hint: Start of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Hint: End of reading config file /usr/lib/codetyphon/fpc/bin/i386-linux/fpc.cfg
Free Pascal Compiler version 2.7.1 [2014/08/28] for i386
Target OS: Linux for i386
Compiling fcllaz.pas
Fatal: Can't find unit system used by fcllaz
Fatal: Compilation aborted
Makefile:2565: recipe for target 'fcllaz.ppu' failed
make[1]: Leaving directory '/usr/lib/codetyphon/typhon/packager/registration'
Makefile:2598: recipe for target 'registration' failed
mv: cannot stat `typhon': No such file or directory
mv: cannot stat `typhonstart': No such file or directory
mv: cannot stat `typhonbuild': No such file or directory
mv: cannot stat `tools/lazres': No such file or directory
mv: cannot stat `tools/lrstolfm': No such file or directory
mv: cannot stat `tools/svn2revisioninc': No such file or directory
mv: cannot stat `tools/updatepofiles': No such file or directory
[INFO]: Clean Tools Directory
              Strip Typhon32 Executables
[INFO]: make some links...
chmod: cannot access `/usr/share/applications/typhon32': No such file or directory
[ERROR]: Sorry, Typhon32 Small IDE NOT Build
Terminate Action at 3-9-14 13:00:34
Total time: 00:00:00.956
ExitCode : 0
arm-linux raspberry pi 10 years 8 months ago #5902
MultiArch don't work on Debian Sir
look here for MultiArch Linux
We use in our lab Fedora 20 64bit for MultiArch
The following user(s) said Thank You: zeljko
arm-linux raspberry pi 10 years 8 months ago #5903
  • zeljko
OK
3. Debian Family
(Debian, Ubuntu, Mint, Kali, WattOS, etc)
All executables stored in usr/bin directory
32bits libraries stored in /usr/lib/i386-linux-gnu
64bits libraries stored in /usr/lib/x86_64-linux-gnu
CodeTyphon MultiArch on this family is under exploration...
