Pascal - Variable Types
- Category: Chapter 1
- Published: Sunday, 14 April 2013 14:19
- Hits: 26955
A variable is nothing but a name given to a storage area that our programs can manipulate. Each variable in Pascal has a specific type, which determines the size and layout of the variable's memory; the range of values that can be stored within that memory; and the set of operations that can be applied to the variable.
The name of a variable can be composed of letters, digits, and the underscore character. It must begin with either a letter or an underscore. Pascal is not case-sensitive, so uppercase and lowercase letters mean same here. Based on the basic types explained in previous chapter, there will be following basic variable types:
1. Basic Variables in Pascal
| Type | Description |
| Character | Typically a single octet (one byte). This is an integer type. |
| Integer | The most natural size of integer for the machine. |
| Real | A single-precision floating point value. |
| Boolean | Specifies true or false logical values. This is also an integer type. |
| Enumerated | Specifies a user-defined list. |
| Subrange | Represents variables whose values lie within a range. |
| String | Stores an array of characters. |
Pascal programming language also allows defining various other types of variables which we will cover in subsequent chapters like Pointer, Array, Records, Sets, and Files etc. For this chapter, let us study only basic variable types.
2. Variable Declaration in Pascal
All variables must be declared before we use them in Pascal program. All variable declarations are followed by the var keyword. A declaration specifies a list of variables, followed by a colon (:) and the type. Syntax of variable declaration is:
var variable_list : type;
Here, type must be a valid Pascal data type including character, integer, real, boolean, or any user defined data type etc., and variable_list may consist of one or more identifier names separated by commas. Some valid variable declarations are shown here:
var age, weekdays : integer; taxrate, net_income: real; choice, isready:boolean; initials, grade:char; name, surname :string;
In the previous tutorial, we have discussed that Pascal allows declaring a type. A type can be identified by a name or identifier. This type can be used to define variables of that type. For example,
type days, age = integer; yes,true=boolean; name, city =string; fees, expenses = real;
Now, the types so defined can be used in variable declarations:
var weekdays, holidays : days; choice: yes; student_name, emp_name : name; capital: city; cost: expenses;
Please note the difference between type declaration and var declaration. Type declaration indicates the category or class of the types such as integer, real etc., whereas the variable specification indicates the type of values a variable may take. You can compare type declaration in Pascal with typedef in C. Most importantly, the variable name refers to the memory location where the value of the variable is going to be stored. This is not so with the type declaration.
3. Variable Initialization in Pascal
Variables are assigned a value with a colon and the equal sign, followed by a constant expression. The general form of assigning a value is:
variable_name := value;
By default, variables in Pascal are not initialized with zero. They may contain rubbish values. So it is a better practice to initialize variables in a program. Variables can be initialized (assigned an initial value) in their declaration. The initialization is followed by the var keyword and the syntax of initialization is as follows:
var variable_name : type = value;
Some examples are:
age: integer =15; taxrate: real =0.5; grade:char='A'; name:string='John Smith';
Let us look at an example which makes use of various types of variables discussed so far:
program Greetings; const message =' Welcome to the world of Pascal '; type name =string; var firstname, surname: name; begin writeln('Please enter your first name: '); readln(firstname); writeln('Please enter your surname: '); readln(surname); writeln; writeln(message,' ', firstname,' ', surname); end.
Please enter your first name: John Please enter your surname: Smith Welcome to the world of Pascal John Smith
4. Enumerated Variables
You have seen how to use simple variable types like integer, real and boolean. Now let's see variables of enumerated type which can be defined as:
var var1, var2,... :enum-identifier;
When you have declared an enumerated type, you can declare variables of that type. For example,
type months =(January,February,March,April,May,June,July,August,September,October,November,December); Var m: months;... M :=January;
The following example illustrates the concept:
program exEnumeration; type beverage =(coffee, tea, milk, water, coke, limejuice); var drink:beverage; begin writeln('Which drink do you want?'); writeln('You have ',sizeof(drink),' choices'); end.
Which drink do you want? You have 4 choices
5. Subrange Variables
Subrange variables are declared as:
var subrange-name : lowerlim ... uperlim;
Examples of subrange variables are:
var marks:1...100; grade:'A'...'E'; age:1...25;
The following program illustrates the concept:
program exSubrange; var marks:1..100; grade:'A'..'E'; begin writeln('Enter your marks(1 - 100): '); readln(marks); writeln('Enter your grade(A - E): '); readln(grade); writeln('Marks: ', marks,' Grade: ', grade); end.
Enter your marks(1 - 100): 100 Enter your grade(A - E): A Marks: 100 Grade: A
