can't istall brook package 6 years 11 months ago #13971
  • Fiat
  • Fiat's Avatar Topic Author
i cant install brook framework how can install this package?
https://eksiup.com/p/s7243063xv2b
Last edit: by Fiat.
can't istall brook package 6 years 11 months ago #13972
It's in then CT Sir
pl_Brook package
can't istall brook package 6 years 11 months ago #13973
  • Fiat
Hello
İ cant find brook framework project in file>new>other>
So how can i start a brook framwork project ?
can't istall brook package 6 years 11 months ago #13976
back to the basics... :)
Please,
-Your OS ?
-Your CT version ?
etc..
-Did you install pl_Brook package in to Typhon IDE ?
-Which Typhon IDE 32Bits or 64Bits ?
can't istall brook package 6 years 11 months ago #13977
  • Fiat
Typhon ide 32 bit. Win 10 typhon is last version i just download.
can't istall brook package 6 years 11 months ago #13978
  • Peter Heckert
  • Peter Heckert's Avatar
This package is not installed in default CT 6.9 32 bit IDE.
I think, you must goto Package->install/uninstall packages and install the framework.
Alternatively, if you are on win 64 bit, then you can build the big 32 bit IDE.
The latter is not possible on win 32, only on win 64 bit, because it needs about 3 GB of free memory.
However, you can build the big 32 bit IDE on win 64 and then copy the ct folder to a 32 bit machine.
Last edit: by Peter Heckert.
