VisibleExpression on FPReport 7 years 2 months ago #13513
  • Max
  • Max's Avatar Topic Author
I try to put VisibleExpression on a control in the data band, but I can't refer to the value of the field.
For example, if I type: 'A' = 'B' the expression works, but if I insert in the VisibleExpression the condition: [fieldname] = 'B' does not work. I get an error from EExprScanner which says: unknown character at pos 1: '['.
Can anyone tell me why?
(code typhon 6.8 with fpc 3.31 on windows 10)
VisibleExpression on FPReport 7 years 2 months ago #13514
A source sample ?
VisibleExpression on FPReport 7 years 2 months ago #13515
  • Max
I have uploaded an example with the described case. I would like to be able to display / hide an image
based on the field retrieved (in this case 'Y' or 'N')
VisibleExpression on FPReport 7 years 2 months ago #13516
  • Max
I solved the problem!
In the VisibleExpr condition of the image control, instead of:
[APPROVED] = 'Y';
I put:
IF (APPROVED = 'Y', TRUE, FALSE)
and the report is created correctly.
Last edit: by Max. Reason: Wrong example
VisibleExpression on FPReport 7 years 2 months ago #13517
