Installation CT on Mac 10.9.4 11 years 6 months ago #5975
  • Jos Wegman
  • Jos Wegman's Avatar Topic Author
  • Thank you received: 4
Basic support for Mac available in CT 5.00. Great work!
I tried to install it from terminal as root.
Not succesfull to install yet.
XCode 5 wants to install. There are no commandline tools for that version. At least I get an error intrying to install Xcode.
Can you explain briefly how you installed CT on a Mac. Or where I can find documentation about it.
Please point me in the right dirention.
Any help or instructions are welcome.
Thank you
Jos
The following user(s) said Thank You: kenlee
Installation CT on Mac 10.9.4 11 years 6 months ago #5977
  • Thank you received: 1129
the steps for CT On MacOS 10.9.x are the same as any other Unix (until now)
We working and on this Lab Task
for your help:
1) install XCode: in a terminal run: xcode-select --install
2) Get Sudo permitions:in a terminal run: visudo
and add at last line: user ALL=(ALL) NOPASSWD: ALL
"Esc" and "zz" to save and exit from vi editor
Now download CT to Download directory
extract (open)
open a terminal: go to CodeTyphonInst :cd CodeTyphonInst
and run as normal user sh ./install.sh
-How to view Root directory and subdirectories ( /usr/lib, etc..) in Mac OS Finder?
in a terminal run: sudo chflags -R nohidden /*
Installation CT on Mac 10.9.4 11 years 6 months ago #5978
  • Jos Wegman
Thank you Sir.
I will try to install.
Jos
