Ver 6.90: Missing components in 32 bits IDE 6 years 11 months ago #13833
  • Ramon Retamar
  • Ramon Retamar's Avatar Topic Author
Hi.
I download and install CT 6,90 and perform a clean-installation. Compilation ending ok, but any components (like fortes report) are present in 64 bits IDE version, but are missing into 32 bits IDE. :blink:
Any idea ? The environment for compilation is Win7 x64 SP1 with 16 Gb of RAM (and AVG antivirus disabled, for prevent false detections). I have a lot of free disk space.
Thanks, Ramon
Last edit: by Ramon Retamar.
Ver 6.90: Missing components in 32 bits IDE 6 years 11 months ago #13835
in CodeTyphon 6.90 we decide to minimize the memory request by CT to build Typhon32 (32bits) BigIDE.
We set the upper limit to 1GByte of RAM, because 32bit OSes support until 2GByte of RAM.
Many users have problem to build Typhon32 (32bits) BigIDE with old CT 6.80 packages configuration.
You can manual add packages to Typhon32 (32bits) BigIDE more info here
Typhon64 on ALL host OSes, will continue to have the maximum numbers of packages, with upper limit to 4GByte of RAM.
THE time has come for 32bit OSes...
Ver 6.90: Missing components in 32 bits IDE 6 years 11 months ago #13836
  • Thank you received: 228
++1
Ver 6.90: Missing components in 32 bits IDE 6 years 11 months ago #13837
  • Ramon Retamar
Thanks for fast and precise reply !!! :)
