Error reading data from socket. 7 years 6 months ago #13166
  • Fernando
  • Fernando's Avatar Topic Author
When doing long (many files) updates via CTC, in some cases (connection problems), I am greeted intermittently with the error message:
Press OK to ignore and risk data corruption.
Press Abort to kill the program.
[OK] [Abort]
And the only solution, as far I know, is to press OK and start all downloading over again. Is there any way to continue form the point where the error raised? that is, at the file which download failed.
Error reading data from socket. 7 years 6 months ago #13168
No yet Sir
we will add this to our CT To-Do list
The following user(s) said Thank You: Fernando
Error reading data from socket. 7 years 2 months ago #13483
  • Wolfgang
  • Wolfgang's Avatar
I also had the same problem on windows7-64. Each update was stopped by this message.
My solution was to stop all applications, which use the internet connection, except CTC. Then the update ran without any problem.
