Configuration Error 12 years 2 months ago #4511
  • Ahmad
  • Ahmad's Avatar Topic Author
I want config CT for cross-build but occur below Error:
I did and the errors across different settings that insert into attachment files.
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\system.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\objpas.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\sysutils.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\windows.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\sysconst.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\windirs.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\classes.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\rtlconsts.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\types.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\typinfo.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\dos.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
Error: Unit C:\codetyphon\fpcsrc\rtl\units\i386-win32\strings.ppu was compiled using a different whole program optimization feedback input (C:\codetyphon\fpcsrc\compiler\pp2.wpo, 2013/09/22 18:46:54); recompile it without wpo or use the same wpo feedback input file for this compilation invocation
fpcmdic.pp(71,1) Fatal: There were 12 errors compiling module, stopping
Configuration Error 12 years 2 months ago #4513
  • Thank you received: 1127
Sir all are OK in both files
[FINAL INFO]: -- !!! win32 arm-android Cross Build Element Build OK !!! --
If you can see arm-android Cross FPC units in folder
C:\codetyphon\fpc\units\ all are OK
and ready to build you arm-android Projects
The following user(s) said Thank You: Ahmad
Configuration Error 12 years 2 months ago #4515
  • Ahmad
Thanks sir.
Yes I see but I cannot compile a project for android. (even an empty project)
Because there are these errors.
Note: I did these settings.
