dcpcrypt problem 12 years 10 months ago #2489
  • Pierre Joubert
  • Pierre Joubert's Avatar Topic Author
Thank you for CodeTyphon!
I have code that works in Lazarus for Windows. In 64bit Lazarus for Linux, I have a problem, please help.
Here is the error message:
Project raised exception class 'External: SIGSEGV'.
In file 'source/Ciphers/dcprijndael.pas' at line 239:
PDword(@a[1,0])^:= PDword(dword(@InData)+4)^;
Here is the source code (dcp: TDCP_rijndael):
function Encrypt(str: string): string;
dcp.InitStr(String of 130 Characters, TDCP_sha256);
result := dcp.EncryptString(str);
dcpcrypt problem 12 years 10 months ago #2490
  • Rain
  • Rain's Avatar
I assume your Windows test was in Win32, not Win64 ?
Probably this code works in 64bit environments better:
(just forcing qword instead of dword, because in 64bit-OS a pointer (e.g. to InData) is a qword, so the pointer should not be truncated to 32bit (dword), which will definetly crash):
PDword(@a[0,0])^:= PDword(@InData)^;
PDword(@a[1,0])^:= PDword(qword(@InData)+4)^;
PDword(@a[2,0])^:= PDword(qword(@InData)+8)^;
PDword(@a[3,0])^:= PDword(qword(@InData)+12)^;
dcpcrypt problem 12 years 10 months ago #2492
  • Rain
  • Rain's Avatar
Those files contain either / or
... dword(@ ...
... longword(@ ...
and will therefore crash on 64bit compiled executables:
fpcsrc\rtl\go32v2\sysutils.pp
fpcsrc\rtl\morphos\muihelper.pas
fpcsrc\tests\test\tcmp.pp
fpcsrc\tests\test\tindex.pp
fpcsrc\tests\webtbs\tw2676.pp
lazarus\components\pl_ACS\source\win\win_acs_audio.inc
lazarus\components\pl_DCP\source\dcpcrypt2.pas
lazarus\components\pl_DCP\source\Ciphers\dcpblowfish.pas
lazarus\components\pl_DCP\source\Ciphers\dcpcast128.pas
lazarus\components\pl_DCP\source\Ciphers\dcpcast256.pas
lazarus\components\pl_DCP\source\Ciphers\dcpdes.pas
lazarus\components\pl_DCP\source\Ciphers\dcpgost.pas
lazarus\components\pl_DCP\source\Ciphers\dcpice.pas
lazarus\components\pl_DCP\source\Ciphers\dcpidea.pas
lazarus\components\pl_DCP\source\Ciphers\dcpmars.pas
lazarus\components\pl_DCP\source\Ciphers\dcpmisty1.pas
lazarus\components\pl_DCP\source\Ciphers\dcprc2.pas
lazarus\components\pl_DCP\source\Ciphers\dcprc4.pas
lazarus\components\pl_DCP\source\Ciphers\dcprc5.pas
lazarus\components\pl_DCP\source\Ciphers\dcprc6.pas
lazarus\components\pl_DCP\source\Ciphers\dcprijndael.pas
lazarus\components\pl_DCP\source\Ciphers\dcpserpent.pas
lazarus\components\pl_DCP\source\Ciphers\dcptea.pas
lazarus\components\pl_DCP\source\Ciphers\dcptwofish.pas
lazarus\components\pl_GLScene\source\VideoAPIs\GLSVfw.pas
lazarus\components\pl_KControls\source\kicon.pas
The solution is already in
c:\codetyphon\lazarus\components\pl_DCP\source\dcpcrypt2.pas :
For 64bit CodeTyphon Project
{$ifdef CPU32}
xlongword=longword;
{$endif}
{$ifdef CPU64}
xlongword=QWord;
{$endif}
But this defined xlongword is not consequently used afterwards everywhere where is would be indicated to be used.
dcpcrypt problem 12 years 10 months ago #2493
  • Pierre Joubert
Thank you.
Yes, I am using 32bit windows (Windows XP).
I changed /usr/lib/codetyphon/lazarus/components/pl_DCP/source/dcpcrypt2.pas to:
// dword= longword;
Pwordarray= ^Twordarray;
Twordarray= array[0..19383] of word;
Pdwordarray= ^Tdwordarray;
Tdwordarray= array[0..8191] of dword;
{$ifdef CPU32}
xlongword=longword;
{$endif}
{$ifdef CPU64}
xlongword=QWord;
{$endif}
//Pierre
dword= xlongword;
After rebuilding Lazarus I got the following error:
In file 'source/Ciphers/dcprijndael.pas' at line 183:
tk[0,0]:= tk[0,0] xor rcon[rconpointer];
Replacing all occurences of longword in dcprijndael.pas with QWord did not work.
dcpcrypt problem 12 years 10 months ago #2494
  • Rain
  • Rain's Avatar
Please restore all files (including dcpcrypt2.pas) to the original CT version.
Only replace the existing
c:\codetyphon\lazarus\components\pl_DCP\source\Ciphers\dcprijndael.pas
with the attached one.
File Name: dcprijndael.zip
File Size:3 KB
Do nothing else. ;)
Last edit: by Rain.
dcpcrypt problem 12 years 10 months ago #2495
  • Graeme Geldenhuys
  • Graeme Geldenhuys's Avatar
No, no no....
DCPCrypt has already been fixed for 64-bit systems. You guys (and it seems CodeTyphon) are all using an outdated version of DCPCrypt. The latest version is v2.0.4.1 released back in 2010-03. This release added some vital 64-bit fixes that was overlooked in the v2.0.4 release.
Get the latest DCPCrypt code from...
git clone git://lazarus-ccr.git.sourceforge.net/gitroot/lazarus-ccr/dcpcrypt
The sample code posted in the beginning of this thread works 100% here on my 64-bit Linux system (and on 32-bit Linux/Windows systems).
Last edit: by Graeme Geldenhuys.
dcpcrypt problem 12 years 10 months ago #2496
  • Graeme Geldenhuys
You are not using the latest DCPCrypt code! The latest is v2.0.4.1 and you can get it from...
That will fix your problem. You code runs fine here on my 64-bit system.
dcpcrypt problem 12 years 10 months ago #2497
  • Rain
  • Rain's Avatar
Oh well, in this case, :) here is a http link I found, if git access is not possible for everyone:
sourceforge.net/projects/lazarus-ccr/fil...2.0.4.1.zip/download
dcpcrypt problem 12 years 10 months ago #2498
  • Thank you received: 1124
We will update this package
