Lazarus 64-bit big IDE setup 13 years 4 months ago #1800
  • Thomas
  • Thomas's Avatar Topic Author
just joined and I also wanted to say I love the work you guys are doing on CodeTyphon and making FreePascal accessible to everybody :) Thanks!
I had some trouble installing the Lazarus 64 Big IDE on Windows 7 x64 (Small IDE worked fine), and I noticed it seems to be due to a little mistake in the script. I am using 2.50 and there seems to be an accidental "bin32" in the installation script where it should be "bin64" (unless you have already hotfixed it). I edited the script and now it works fine (if I didn't edit it then the script would report success but the IDE would still be missing all the extra components and units).
The script is in "codetyphon\x_Lazarus_Win64_Build.bat"
Just posting this here so people who are having the same problem I had can hopefully fix it instead of spending three days removing/reinstalling CT repeatedly (and it also gives me a reason for creating this forum account).
Last edit: by Thomas. Reason: typo
Re: Lazarus 64-bit big IDE setup 13 years 4 months ago #1801
  • Thank you received: 1124
We fix this error
Re: Lazarus 64-bit big IDE setup 13 years 4 months ago #1802
  • Tom
  • Tom's Avatar
Do you check Libraries Tab in Code Typhon Center?
I have the same problem and fixed with install DirectX 9 and Run as Administrator Code Typhon Center and Clean and Build All.
Win7 Pro 64b
Re: Lazarus 64-bit big IDE setup 13 years 4 months ago #1808
  • Thomas
ttomas wrote: Do you check Libraries Tab in Code Typhon Center?
Win7 Pro 64b
Nah I have all the libraries in CT center except a few DX8 64-bit libraries I did run it as administrator and I did clean and build all several times (in fact I tried about 10 different combinations of reinstalling and removing CodeTyphon). It just wouldn't work until I repaired the script, then it worked perfectly :)
