Better look for coding 6 years 1 month ago #11476
  • Edgar Rodriguez
  • Edgar Rodriguez's Avatar Topic Author
Hi, I think we could make a little change on the IDE look inside the editor for better reading... Solid lines are visually annoying compared to dotted lines. Here's a comparison with Notepad++.
Better look for coding 6 years 1 month ago #11477
  • Thank you received: 1101
Typhon Code Editor has full customization.
Please go to Typhon=>IDE Options => Editor=>Display
and select your options
or
load one of ready Color samples.
Please, search to www for more Color samples
Better look for coding 6 years 1 month ago #11483
  • Edgar Rodriguez
Dear friend, believe me when I say that I tried all the colors, and the problem is not on the colors, the problem is on the line styles... they are solid, and I wish I could put them dotted like in Notepad++
