Library announcement: Generics.Collections 12 years 2 months ago #3882
  • HNB
  • HNB's Avatar Topic Author
Hi Code Typhon community!
I'm pleased to announce the generic library, compatible with Delphi Generics.Collections (almost ;) ).
Homepage
code.google.com/p/fpc-generics-collections/
ZIP
code.google.com/p/fpc-generics-collections/downloads/list
SVN
fpc-generics-collections.googlecode.com/svn/trunk/
modules
  • Generics.Defaults
  • Generics.Collections
  • Generics.Helpers
  • Generics.Hashes
compatible classes
  • TEnumerator<T>
  • TEnumerable<T>
  • TList<T>
  • TQueue<T>
  • TStack<T>
  • TDictionary<TKey, TValue>
  • TObjectList<T: TObject>
  • TObjectStack<T: TObject>
  • TObjectDictionary<TKey, TValue>
renamed (because compiler limations/bug)
  • TArrayHelper<T> instead of TArray<T>
additional classes
  • TDictionary<TKey, TValue, TProbeSequence, THash, THashFactory>
    TObjectDictionary<TKey, TValue, TProbeSequence, THash, THashFactory>
    TKey - key, TValue - value, THashFactory - hash factory :)
    TProbeSequence - TProbeSequence is special record for open addresing. To choose from a predefined:
    TLinearProbing, TQuadraticProbing, TDoubleHashing,
    TFastLinearProbing, TFastQuadraticProbing, TFastDoubleHashing (fast version is without "mod")
    more info at en.wikipedia.org/wiki/Open_addressing
    THash - type for hash (to reduce size of dictionary - can be UInt8, UInt16, UInt32 etc.)
    For example, Delphi TDictionary version in this library is defined as:
    TDictionary<TKey, TValue> = class(TDictionary<TKey, TValue, TFastLinearProbing, UInt32, TDelphiHashFactory>);
  • TDictionaryList<TKey, TValue, TIndex, THash, THashFactory>
    class, that combines a TList and TDictionary
    TIndex - type for index (to reduce size of dictionary - can be UInt8, UInt16, UInt32 etc.)
  • Similar to TList, TDictionary and TDictionaryList, but uses normal operators instead of IEqualityComparer.
    • TFastList
    • TFastDictionary
    • TFastDictionaryList
  • TFastArrayHelper<T> - similar rules as above
not implemented
TThreadedQueue<T>
FAQ
1. How to use record as Key or Value in dictionary?
You need to wait for some compiler magic ( system functions GetReferenceToValue and GetValueSize described bolow)
or add two methods to record:
TRecord = record
      function GetValueSize: Integer; inline;
      function GetReferenceToValue: Pointer; inline;
2. How to use Pointer or some custom type as Key or Value in dictionary?
or use TValueHelper:
uses
      Generics.Collections, Generics.Helpers;
      type
        TValueHelperPointer = TValueHelper<Pointer>;
        d: TDictionary<TValueHelperPointer, string>;
        d.Add(nil, 'foo');
TODO
Comparer from Generics.Defaults can be optimized.
I have no knowledge of FPC compiler design, so i need a little help...
First thing : To finish my work I need critical compiler magic functions/feature. At first look mayby there is no sense for this functions
but during work on Generic library it's necessary:
function GetReferenceToValue(Value: T): Pointer; // for string types return @s[1] or nil for empty string for Int32 return @i etc. returns a reference to the value, as measured by human/programmer
  function GetValueSize(Value: T): Integer; // for string types return Length(s), for Int32 returs 4 etc.
This functions should be implemented as operators (like Inc, Dec operators).
There is half-workaround/cripled solution as record/type helpers (module Generics.Helpers). Don't work for custom strings, and for custom "basic" types like:
type MyStr = type string;
  type MyInt = type Int32;
Second thing: Bugs. Look at Critical - fix is needed to perform compatibility with Delphi and proper work.
Regards,
HNB
Last edit: by HNB.
Library announcement: Generics.Collections 12 years 2 months ago #3883
  • Thank you received: 1124
we will view your source
and we will report here
Library announcement: Generics.Collections 12 years 2 months ago #3892
  • HNB
Thanks! I'm waiting for reports. There's still a lot of work. If you help me with testing my library, it will be nice...
