Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13677
  • Jose Ceravolo
  • Jose Ceravolo's Avatar Topic Author
Hi All,
I am new to CT and I have a procedure that sets up a filter in a dataset.
It works in Delphi, but I can't get to work with CT.
The filter is UPPER(NAME) like '%C%'.
That should return any NAME that contains a C character in it.
Thanks in advance,
Jose.
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13678
First of all we don't use Delphi. :)
Please give us more info:
Your OS, a code sample.
etc
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13680
  • Jose Ceravolo
Hello Sternas,
I am using Windows 10.
Here's the code:
procedure TfrmDataBrowser.btApplyClick(Sender: TObject);
if dsData.DataSet.FieldByName(lcFilter) is TStringField then
dsData.DataSet.Filter := 'UPPER(' + lcFilter + ') like ' + quotedstr('%' + uppercase(edtSearch.Text) + '%');
end
else dsData.DataSet.Filter := lcFilter + ' = ' + edtSearch.Text;
dsData.DataSet.Filtered := true;
edtSearch.SelectAll;
edtSearch.SetFocus;
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13681
Try this
end
edtSearch.SetFocus;
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13683
  • Jose Ceravolo
It's the same, it does not return any records.
It still works for integer fields.
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13684
My suggestion is
to attach here a test project
dsData.DataSet.Refresh;
end
edtSearch.SetFocus;
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13685
  • Jose Ceravolo
Ok, I created a working test project.
The idea is to click on the title of the grid to be able to search that field.
It works with the integer field.
File Name: TestProject.zip
File Size:671 KB
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13688
For which Firebird ver is your NEWDATABASE.FDB ?
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13689
  • Jose Ceravolo
Firebird 3
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13692
  • Jose Ceravolo
I got it to work by replacing the % for *.
I wonder why that is. The % should work with Firebird.
Anyway, it's working, but it should not be like that.
Thanks,
Jose.
Filtering dataset not working CT6.8 - Firebird 3 7 years 2 weeks ago #13693
have fun
