ibx4lazarus 11 years 7 months ago #2528
  • Miquel Matas
  • Miquel Matas's Avatar Topic Author
  • Thank you received: 10
Sternas,
Is it possible to add ibx4lazarus into CT?
www.mwasoftware.co.uk/index.php?option=c...ew&id=102&Itemid=133
Why IBX and Why Lazarus
Cheers,
Miquel.
Last edit: by Miquel Matas.
ibx4lazarus 11 years 7 months ago #2540
  • Konstantinos Papadoulas
  • Thank you received: 19
I am not deep into Databases but wouldn't ZeosDBO do the job with Interbase/Firebird databases?
What is the benefit of using ibx4lazarus over ZeosDBO? There is a case that i might get involved in an
application that will need to access Firebird database and i would like to know the best tool for this purpose
Kostas
ibx4lazarus 11 years 7 months ago #2547
  • Miquel Matas
I really do not know the differences. I will check.
Cheers,
ibx4lazarus 11 years 7 months ago #2548
  • FredyCC
  • FredyCC's Avatar
  • Database/Developer
I have used Zeos to connect to a Firebird/SQLite databases on Windows / Linux / Mac OSX, some problems with symlinks but works well.
ibx4lazarus 11 years 7 months ago #2549
  • Miquel Matas
Which version? stable or alpha.
Gracias! :)
ibx4lazarus 11 years 7 months ago #2550
  • FredyCC
  • FredyCC's Avatar
For Firebird 2.5.x I prefered use SVN reporsitory for Zeos and works ok for me :)
Last edit: by FredyCC.
ibx4lazarus 11 years 6 months ago #2571
..so.. tham means i'll stick with ZeosDBO ;)
ibx4lazarus 8 years 6 months ago #8295
  • Jason Wharton
  • Jason Wharton's Avatar
I realize this is old, but you can also use IB Objects to connect to Firebird/InterBase with FPC/Lazarus.
Jason Wharton
www.ibobjects.com
ibx4lazarus 8 years 2 months ago #9037
  • Emil Odjackov
  • Emil Odjackov's Avatar
Excuse me, but I can't install the IBX package. I follow the instructions from \doc\readme.xhtml :
" .... open the “dclibx.lpk” package description file using the “Package->Open Package File” menu item to open the file.
When the Package Editor opens, click on “Use->Install”. Lazarus should now recompile itself and restart. ..."
Unfortunately I have a message :
"Error: One or more required packages were not found. See package graph for details."
there is a graph, that shows IDEIntf as missing :evil:
Please help me to fix above problem ?
ibx4lazarus 8 years 2 months ago #9038
  • Mihai Nester
  • Mihai Nester's Avatar
Open package dclibx.lpk. Change IDEIntf with bs_IDEIntf. Compile and Install. This is all.
The following user(s) said Thank You: Emil Odjackov
ibx4lazarus 8 years 2 months ago #9039
  • Emil Odjackov
I installed IBX components successfully, but after CodeTyphon rebuilt itself they are not appear for use and every time I start CT I see a message:
"IBX is unable to locate the Firebird Library - have you remembered to install it ?".
What can I do, to fix this ?
ibx4lazarus 8 years 2 months ago #9041
  • usbdoo
  • usbdoo's Avatar
you must first install Firebird and FlameRobin
and then IBX
ibx4lazarus 8 years 2 months ago #9046
  • Emil Odjackov
usbdoo wrote: you must first install Firebird and FlameRobin
and then IBX
I have 2 home computers with 32 bits Firebird server 2.5.5.26952 installed under Windows 8.1 and Windows 7 - both OS 64 bits.
I did search through Google and found flamerobin-0.9.2-1-setup.exe from sourceforge.net, then I did install it.
The problem persists ....
May be I have to uninstall and then again install the IBX components ?
ibx4lazarus 8 years 2 months ago #9049
  • wilhelm
  • wilhelm's Avatar
Adding Firebird 2.5 and Firebird 2.5\bin path to system variable 'path' will resolve
ibx4lazarus 8 years 2 months ago #9051
  • Emil Odjackov
1. I did add : C:\Program Files (x86)\Firebird\Firebird_2_5\bin; into System variable Path, but the problem persists;
2. I did remove the dclibx from installed packages and Save and rebuild IDE, then after restart I did install dclibx.lpk, Save and rebuild IDE, then after restart the problem persists - every time I start CT I see a message:
Last edit: by Emil Odjackov.
ibx4lazarus 8 years 2 months ago #9052
  • wilhelm
  • wilhelm's Avatar
have you performed installation of 'gds32.dll' ( must by in ..\windows\syswow64).
Usage:
instclient i[nstall] [ -f[orce] ] library [with admininstrator privilegies]
q[uery] library
r[emove] library
where library is: f[bclient] | g[ds32]
instclient will put file in System32; copy to syswow64
for further info see ..ibx\doc\readme.windows.xhtml (.How IBX Finds the Firebird DLL)
i hope now it will work
ibx4lazarus 8 years 2 months ago #9053
  • Emil Odjackov
I give up ....
I can not make IBX components to work.
Everything is o.k. - 3 files: fbclient.dll, firebird.conf and firebird.msg exist in C:\Windows\System32 and in C:\Windows\SysWOW64.
HKEY_LOCAL_MACHINE\SOFTWARE\Firebird Project\Firebird Server\Instances
contains
a string value name : DefaultInstance
a string value data : C:\Program Files (x86)\Firebird\Firebird_2_5\
Immediateli on starting of CodeTyphon, there is no project opened, I see that message:
Do you think I will able to work with Firebird and Zeos components of CodeTyphon ?
ibx4lazarus 8 years 2 months ago #9054
  • Jason Wharton
Are you willing to use IB Objects to connect to Firebird?
I am actively developing and supporting IBO for Free Pascal Compiler.
Under the terms of the Trustware License you can use it without cost because you are trusted to pay if and when you deem that it has benefitted you financially to justify paying a license fee.
Jason Wharton
www.ibobjects.com
ibx4lazarus 8 years 2 months ago #9055
  • Emil Odjackov
Jason Wharton wrote: Are you willing to use IB Objects to connect to Firebird?
I will try IB Objects to connect to Firebird.
ibx4lazarus 8 years 2 months ago #9056
  • Jason Wharton
You will need to get the full source to do so.
Please contact me privately at Jason -at- ibobjects dot com.
Jason Wharton
www.ibobjects.com
