How class/component to use for map strin->integer or pointer? 6 years 9 months ago #14174
  • Andrzej B
  • Andrzej B's Avatar Topic Author
or other maps;
If templates are enabled in FreePascal?
How class/component to use for map strin->integer or pointer? 6 years 9 months ago #14175
Please Sir
what exactly do you mean ?
How class/component to use for map strin->integer or pointer? 6 years 9 months ago #14176
  • Andrzej B
There is module fgl.pp and has
generic TFPGMap<TKey, TData> = class(TFPSMap)
but I can't add fgl in uses part. In which package is fgl?
Maybe modules with generic are not visible untilI set options "enable generic"?
How class/component to use for map strin->integer or pointer? 6 years 9 months ago #14179
fgl.pp is part of FPC (FreePascal)
C:\codetyphon\fpcsrc\rtl\objpas\fgl.pp
so NOT need to add any Typhon IDE package to your app.
Just add to you app "uses" fgl unit, the compiler (FPC) know where FPC files are.
FPC don't knows where Typhon IDE files are, for this reason you must add packages to your app
