Character encoding TfrTNPDFExportFilter TlrCairoExportFilter 6 years 10 months ago #14020
  • Peter
  • Peter's Avatar Topic Author
Hello Gurus,
My first Question is:
How can I get this Cairo going?
One problem is that the package does not install. I can select it to be installed but even after rebuild the IDE
it is sill not installed.
frReport1.ExportTo(TlrCairoExportFilter ,'./invoice\'+inv_no+'.pdf'); fails
My second question is :
frReport1.ExportTo(TfrTNPDFExportFilter,'./invoice\'+inv_no+'.pdf'); ok but ..
This one is doing the job, but i have an character encoding problem. The special characters in the German language show up
as gabble in the generated PDF. The preview of the report generated are alright. Any ideas how to fix that ?
I am using codetyphon 6.7 on Win10
Peter
Character encoding TfrTNPDFExportFilter TlrCairoExportFilter 6 years 10 months ago #14021
Please Sir
try and CT 6.9
Character encoding TfrTNPDFExportFilter TlrCairoExportFilter 6 years 10 months ago #14024
  • Peter
Dear Sternas Stefanos,
Thank you for your reply. I have installed 6.9 , but still the special character problem on PDFs .
Thank you for your help.
Character encoding TfrTNPDFExportFilter TlrCairoExportFilter 6 years 9 months ago #14177
  • Klaus Riesterer
  • Klaus Riesterer's Avatar
if frAuftrag.ExportTo(TlrCairoExportFilter, 'print.pdf') then ...
That works for me and solved all problems with german umlauts
