DMath example Mandel - StrToFloat raises exception 7 years 5 months ago #13313
  • Peter Heckert
  • Peter Heckert's Avatar Topic Author
Hi, the reason is this:
Dmath has its own "FloatStr" conversion routine that internaly uses the Pascal Str() function.
Str() does not use the global "Decimalseparator" setting, it apparently uses unconditionally "." as decimalseparator.
Here in germany we have "," as decimalseparator and because the program "Mandel" uses also the routine
FloatToStr different decimalseparators are intermixed and this causes the exception.
I believe it is the best to use "." as decimalseparator in this program unconditionally. This is common in scientific and technical software, because many other programs and measuring instruments - and DMath- use this unconditionally also.
These modifications in "mandelmw.pas" cure the problem for me:
procedure TForm1.FormActivate(Sender: TObject);
  { Display center coordinates in exponential format
    using function FloatStr from unit ustrings }
  DefaultFormatSettings.DecimalSeparator:='.';      // add this line here
  SetFormat(27, 17, True, False);
  Edit2.Text := FloatStr(x0);
  Edit3.Text := FloatStr(y0);
 var xDefaultFormatSettings : TFormatSettings;
{ Plots the Mandelbrot or Julia set }
  Nx, Ny : Integer;
  xt, yt : Float;
  xDefaultFormatSettings:=DefaultFormatSettings;     // ct9999
  //  xDefaultFormatSettings.DecimalSeparator:=',';      //   remove this line    ct9999
  if not SetFractal(StrToFloat(Edit1.Text,xDefaultFormatSettings),
                    StrToFloat(Edit8.Text,xDefaultFormatSettings),
                    StrToFloat(Edit9.Text,xDefaultFormatSettings)) then
Last edit: by Peter Heckert.
DMath example Mandel - StrToFloat raises exception 7 years 5 months ago #13314
we add your fix to Lab CT
