WideString and UTF8 fixes 13 years 7 months ago #3553
  • RockyLuck
  • RockyLuck's Avatar Topic Author
I have identified a number of other places where the UTF8 vs. WideString problem surfaces.
In module orca_scene2d_obj_images.inc, because TD2DragObject.Files[0] is a WideString:
procedure TD2ImageControl.DragOver(const Data: TD2DragObject;
  const Point: TD2Point; var Accept: Boolean);
  inherited;
  // accept correct image file or TD2Image
  Accept :=
      ((Length(Data.Files) > 0) and
//    FileExists(Data.Files[0]) and                  // *** DB ***
      FileExistsUTF8(UTF8Encode(Data.Files[0])) and  // *** DB ***
      (Pos(ExtractFileExt(Data.Files[0]), GvarD2DefaultFilterClass.GetFileTypes) > 0))
    or
      (Data.Source is TD2Image);
In module orca_scene2d_obj_listboxes.inc:
procedure TD2ImageListBox.AddFolder(const Folder: string);
  Dir: string;
  SR: TSearchRec;
  { add folder }
  { add SelectDialog }
  Dir := Folder;
  {$IFDEF UNIX}
  if (Length(Dir) > 0) and (Dir[Length(Dir)] <> '/') then Dir := Dir + '/';
  {$ELSE}
  if (Length(Dir) > 0) and (Dir[Length(Dir)] <> '\') then Dir := Dir + '\';
  {$ENDIF}
  BeginUpdate;
//if FindFirst(Dir + '*.*', $FFFF, SR) = 0 then      // *** DB ***
  if FindFirstUTF8(Dir + '*.*', $FFFF, SR) = 0 then  // *** DB ***
    repeat
      if SR.Name = '.' then Continue;
      if SR.Name = '..' then Continue;
      if SR.Attr and faDirectory = faDirectory then Continue;
      AddFile(Dir + SR.Name);
//  until FindNext(SR) <> 0;                     // *** DB ***
//  FindClose(SR);                               // *** DB ***
    until FindNextUTF8(SR) <> 0;                 // *** DB ***
    FindCloseUTF8(SR);                           // *** DB ***
  EndUpdate;
  if Count > 0 then
    ItemIndex := 0;
In orca_scene2d.pas, the use clause contains ShellAPI and Commctrl. These modules are not used.
Furthermore in orca_scene2d_fn_lang.inc:
procedure LoadLangFromFile(AFileName: string);
//if not FileExists(AFileName) then Exit;      // *** DB ***
  if not FileExistsUTF8(AFileName) then Exit;  // *** DB ***
  ResetLang;
  if varD2Lang = nil then
    varD2Lang := TD2WideStringList.Create;
    varD2Lang.Sorted := true;
    TD2WideStringList(varD2Lang).CaseSensitive := true;
  varD2Lang.LoadFromFile(AFileName);
  UpdateLang;
In orca_scene2d_bitmaps.inc:
procedure TD2Bitmap.LoadFromFile(const AFileName: string; const Rotate: single = 0);
  Filter: TD2Filter;
  Filter := GvarD2DefaultFilterClass.Create;
  if Filter.LoadFromFile(AFileName, Rotate, Self) then
    if Assigned(FOnChange) then FOnChange(Self);
  Filter.Free;
In orca_scene2d_resources.inc:
procedure TD2Resources.Loaded;
  inherited ;
  if FFileName = '' then Exit;
//if FileExists(ExtractFilePath(ParamStr(0)) + FFileName) then      // *** DB ***
  if FileExistsUTF8(ExtractFilePath(ParamStr(0)) + FFileName) then  // *** DB ***
    FResource.LoadFromFile(ExtractFilePath(ParamStr(0)) + FFileName)
  else
//  if FileExists(FFileName) then                                   // *** DB ***
    if FileExistsUTF8(FFileName) then                               // *** DB ***
      FResource.LoadFromFile(FFileName);
procedure TD2Resources.SetFileName(const Value: string);
  if FFileName <> Value then
    FFileName := Value;
    if not (csLoading in ComponentState) then
//    if FileExists(ExtractFilePath(ParamStr(0)) + FFileName) then        // *** DB ***
      else
  Filter: TD2Filter;
  Filter.Free;
In orca_scene2d_lang.inc:
procedure TD2Lang.Loaded;
  L: string;
  inherited;
//if (FFileName <> '') and (FileExists(ExtractFileName(ParamStr(0)) + FFileName)) then     // *** DB ***
  if (FFileName <> '') and (FileExistsUTF8(ExtractFileName(ParamStr(0)) + FFileName)) then // *** DB ***
    LoadFromFile(ExtractFileName(ParamStr(0)) + FFileName);
  if FAutoSelect then
    GetLanguageIDs(L, FLang);
  if FLang <> '' then
    LoadLangFromStrings(LangStr[FLang]);
procedure TD2Lang.LoadFromFile(AFileName: string);
  S: TFileStream;
//if FileExists(AFileName) then         // *** DB ***
  if FileExistsUTF8(AFileName) then     // *** DB ***
    S := TFileStream.Create(AFileName, fmOpenRead);
    ReadResources(S);
    S.Free;
In orca_scene2d_popups.inc there's a strange looking condition (which maybe right, but still it's obscure):
procedure TD2PopupForm.WMDeactivate(var Msg: TLMActivate);
  C: TWinControl;
  inherited ;
//if (not Msg.Active=0) and (FPopup <> nil) and (not FPopup.StaysOpen) then  // *** DB ***
  if (Msg.Active <> 0) and (FPopup <> nil) and (not FPopup.StaysOpen) then   // *** DB ***
    C := FindControl(Msg.ActiveWindow);
Thanks guys ;-}
Dick
Preventing a SIGSEGV exception in pl_ORCA 13 years 7 months ago #3556
  • RockyLuck
In topic 3414 I tried to fix a bug. But that fix was not sufficient. There is another place where things can go wrong. It is a matter of timing in module orca_scene2d_scene.inc, where "FStyle.RemoveSceneUpdater(Self);" is called in the TD2CustomScene.Destroy destructor, which may be too late, because TD2CustomScene does not own the TD2Resources that the style property refers to. So, in this piece of code:
destructor TD2CustomScene.Destroy;
  if FHovered <> nil then
    TD2VisualObject(FHovered).RemoveFreeNotify(Self);
    FHovered := nil;
  if FFocused <> nil then
    TD2VisualObject(FFocused).RemoveFreeNotify(Self);
    FFocused := nil;
//if FStyle <> nil then                   // *** DB ***
//  FStyle.RemoveSceneUpdater(Self);      // *** DB ***
  if GvarD2SceneCount = 0 then
    if GvarD2aniThread <> nil then
the offending statements are removed and placed here:
procedure TD2CustomScene.DestroyWnd;
                   // *** DB *** On other places we may be too late.
                   //            TD2CustomScene.Destroy tried to
                   //            do this, but TD2Resources placed
                   //            on the same form as TD2Scene may
                   //            already be destroyed without being
                   //            nilled.
  if FStyle <> nil then begin         // *** DB ***
     FStyle := nil;                   // *** DB ***
  end{if};                            // *** DB ***
  {$ifdef windows}
  if Canvas <> nil then
    Canvas.Handle := 0;
  {$endif}
  {$IFNDEF UCL}
  {$IFdef WINDOWS}
  if HandleAllocated then
    RevokeDragDrop(Handle);
  if PtrInt(SetWindowLongPtrW(Self.Handle, GWL_WNDPROC, PtrInt(@WndCallback))) = PtrInt(@WndCallback) then
    SetWindowLongPtrW(Self.Handle, GWL_WNDPROC, PtrInt(@PrevWndProc));
  {$ENDIF}
  {$ENDIF}
  inherited ;
In order for this to work on all platforms, this little change is needed as well in orca_scene2d.pas in the properties of TD2CustomScene:
protected
    FUpdateRects: array of TD2Rect;
    procedure CreateHandle; override;
    {$IFDEF WINDOWS}
    procedure CreateWnd; override;
//  procedure DestroyWnd; override;              // *** DB ***
    {$ENDIF}
    procedure DestroyWnd; override;              // *** DB *** (is a method from TWinControl, so present in all platforms)
    procedure InitiateAction; override;
    procedure Loaded; override;
    procedure Resize; override;
Have a nice day!
Dick
TD2StringListBox is crazy 13 years 6 months ago #3572
  • RockyLuck
TD2StringlistBox does not behave as expected when you Assign a TStringList to its Items:
D2StringListBox.Items.Assign(StringList);
The strings will be assigned in totally random order!!!
See the example. Click the Open button to load a non trivial Ascii file. The program adds line numbers to show the horrible result :ohmy:
TD2StringGrid will abort on skin changing 13 years 6 months ago #3611
  • RockyLuck
The accompanying project shows a very serious bug in Orca's grids. The example uses a TD2StringGrid, but I think all grids have this problem: you cannot switch styles for a scene if a grid is placed on it :huh: . It will throw a SIGSEGV violation.
Try it with the test project: checking the check box labeled "Vista" will switch the style from Extreme to Vista and produce the access violation immediately.
The problem is in module orca_scene2d_obj_grids.inc in procedure TD2CustomGrid.UpdateSelection in the line 691:
    TD2VisualObject(FSelections[i]).Visible := Vis;
Apparently the FSelections[ i ] element does not point to a complete TD2VisualObject (only the first part seems to be there).
No response since a month 13 years 6 months ago #3612
  • RockyLuck
I didn't get any response on my bug lists in over a month. Do you appreciate my testing or should I stop?
No response since a month 13 years 6 months ago #3613
No no Sir
We test all your fixes.
We have to many work with upcoming CT ver 4.20 :ohmy:
Bugs found in pl_Orca 13 years 6 months ago #3614
  • Dibo
  • Dibo's Avatar
About orca issues. Don't know if someone reported this but on GTK 64 bit text edits don't work, cursor is changing position but there is no text
No response since a month 13 years 6 months ago #3615
  • RockyLuck
sternas wrote: No no Sir
Fair enough, Sternas. Keep up the good work :cheer:
Bugs found in pl_Orca 13 years 6 months ago #3616
  • RockyLuck
dibo wrote: About orca issues. Don't know if someone reported this but on GTK 64 bit text edits don't work, cursor is changing position but there is no text
The text color may be the same as the background. Did you adjust the "fill" property of the TD2Text element? You can do this by right clicking the component and choosing "Edit Default Style". Then in the TD2Text element edit the Fill property.
List index out of bounds in GradientAnimation 13 years 6 months ago #3675
  • RockyLuck
A bug in orca_scene2d_obj_animations.inc in TD2GradientAnimation.ProcessAnimation may cause an list index out of bounds.
This is the correction:
//        if (i < FStopGradient.Points.Count) or (i < FStartGradient.Points.Count) then       *** DB ***
          if (i < FStopGradient.Points.Count) and (i < FStartGradient.Points.Count) then      *** DB ***
            Points[i].Color := d2ColorToStr(d2InterpolateColor(d2StrToColor(FStartGradient.Points[i].Color),
              d2StrToColor(FStopGradient.Points[i].Color), NormalizedTime));
As you can see, if the number of points in FStartGradient is unequal to the number of points in FStopGradient, the index in the points array for the one or the other will go out of bounds.
Bye ;)
List index out of bounds in GradientAnimation 13 years 5 months ago #3734
  • gorkamorka
  • gorkamorka's Avatar
Hi RockyLuck,
You not only reporting bugs , you give the patches too.i just want to thank you..
SIGSEGV but only when running debugger 13 years 5 months ago #3755
  • RockyLuck
A problem is nagging me for days now:
  • Unzip the attached files to C:\codetyphon\lazarustemp\
  • Now try to run OrcaDBBug in the IDE environment (Win 32 bit).
  • The program runs until you close it (with the Windows Close button).
  • Then you get a SIGSEGV violation.
  • Now run it outside the IDE: nothing happens when you close it: no exception, it just terminates :S
Has anyone ever seen such behavior?
The problem is not with using the obsolete TDbf component, a similar test with sqlite-3 gave the same result.
It has to do with the TD2DBGrid component, but debugging did not deliver any info (mainly because conditional breakpoints simply do not work :angry: )
Regards ;-}
Dick
Last edit: by RockyLuck. Reason: typo
SIGSEGV but only when running debugger 13 years 5 months ago #3777
  • RockyLuck
RockyLuck wrote: A problem is nagging me for days now:
Can anyone please confirm this problem? :angry: :woohoo:
SIGSEGV but only when running debugger 13 years 5 months ago #3778
Please give time Sir
We fight with FPC (Rev 24418) and Lazarus (Rev 41045) mess now...
Buffer flushed, even if nothing to flush 13 years 5 months ago #3779
  • RockyLuck
In orca_scene2D_scene.inc the procedure WMEraseBkgnd is incorrect. Patch as follows:
procedure TD2CustomScene.WMEraseBkgnd(var Msg: TLMEraseBkgnd);
  rgnStatus: integer;
  rgn: HRgn;
  if (Msg.DC <> 0) and (Canvas <> nil) then
    rgn := CreateRectRgn(0, 0, 1, 1);
   {$IFDEF WINDOWS}
    rgnStatus := GetUpdateRgn(Handle, rgn, false);
// {$ENDIF}               // *** DB ***
   {$ELSE}                // *** DB ***
    rgnStatus :=1;
    if (rgnStatus = 1) then
      Canvas.FlushBuffer(0, 0, Msg.DC);
    DeleteObject(rgn);
  Msg.Result := 1;
Buffer flushed, even if nothing to flush 13 years 5 months ago #3780
We will test now
SIGSEGV but only when running debugger 13 years 5 months ago #3781
  • RockyLuck
Well, it doesn't necessarily have to be you guys. Any reader of this forum could do this little test.
WideString and UTF8 fixes 13 years 5 months ago #3782
  • RockyLuck
These fixes didn't make it in release 4.20:
- Item #3553 and Item #3556
- The question in Item #3572 was not yet answered.
- The serious bug shown in Item #3611 was not confirmed.
Sternas, when do you think you'll have the time to implement or look at them?
Regards ;-}
Dick
TD2ComboColorBox doesn't pass value to BindingObj 13 years 5 months ago #3783
  • RockyLuck
In orca_scene2d_obj_comboboxies.inc the ColorComboBox does not pass its changed value to the binding objects. This is the fix:
procedure TD2ComboColorBox.DoColorChange(Sender: TObject);
  FColorText.Text := Color;
  Repaint;
  if Assigned(FBindingObjects) then           // *** DB ***
    ToBindingObjects;                         // *** DB ***
    FOnChange(Self);
TD2AngleButton doesn't pass value to BindingObj's 13 years 5 months ago #3784
  • RockyLuck
Same problem. This is the fix:
procedure TD2AngleButton.SetValue(const Value: single);
  if (FFrequency = 0) then
    if (FValue <> Value) then
      FValue := Value;
      if Tick <> nil then
        Tick.RotateAngle := -FValue
      else
        Repaint;
      Text;
      if Assigned(FOnChange) and (not FPressing or FTracking) then
        FOnChange(Self);
  end
  else
    if FValue <> Round(Value / FFrequency) * FFrequency then
      FValue := Round(Value / FFrequency) * FFrequency;
      if Tick <> nil then
      else
        Repaint;
      Text;
        FOnChange(Self);
