CT LAB ver 5.30 11 years 6 months ago #7152
  • Vbxler
  • Vbxler's Avatar
Hello Mr. Sternas,
I just saw the CTRL-V now fits correctly the clipboard to the properties.
Thank you for this change and the whole project, CT5.30 works fantastic! B)
Vbxler
CT LAB ver 5.30 11 years 6 months ago #7153
more good things will be come...
and always, have fun
CT LAB ver 5.30 11 years 6 months ago #7154
  • usbdoo
  • usbdoo's Avatar
Here's a bug!
if you have two screen.
Run CT 5.3 on the right screen.
Do new form.
Left the wrong calculation and then Form1 not see in CT
If you manually correct unit.lfm then it is ok
object Form4: TForm1
Left = 2170 // <- This is wrong
Left = 1 //If you manually correct unit.lfm then it is ok
Height = 240
Top = 250
Width = 320
Caption = 'Form1'
LCLVersion = '1.5'
end
CT LAB ver 5.30 11 years 6 months ago #7156
  • Leslie
  • Leslie's Avatar
  • Thank you received: 4
The clipboard keyboard shortcuts (ctrl+c ...) are not working in the form designer. It has been like that prior to 5.30 as well. (Kubuntu 14.04, QT4)
Cheers,
Leslie
CT LAB ver 5.30 11 years 6 months ago #7185
we will fix this
CT LAB ver 5.30 11 years 6 months ago #7195
  • user01
  • user01's Avatar
Leslie wrote: Hi,
Cheers,
Leslie
that's what i was talking about. they work, but they fire on source editor cutting, pasting, deleting and backspacing your code.
CT LAB ver 5.30 11 years 6 months ago #7196
  • Al
  • Al's Avatar
Hi, sternas!
In pl_win_directx.lpk need fix all "Source" to "source" and
pl_win_directx\source\XAxt.pas at line 1476 must be fixed to: {$I XAct_asm.inc}
pl_zeosdbo.lpk need this lines for compile for windows platform
      <Item55>
        <Filename Value="source/dbc/ZDbcAdo.pas"/>
        <UnitName Value="ZDbcAdo"/>
      </Item55>
      <Item56>
        <Filename Value="source/dbc/ZDbcAdoMetadata.pas"/>
        <UnitName Value="ZDbcAdoMetadata"/>
      </Item56>
/usr/lib/codetyphon/typhon/ide/compileroptions.pp in lines 2787-2789 need space char before minus sign like:
    1: switches := switches + ' -Rintel';
    2: switches := switches + ' -Ratt';
    3: switches := switches + ' -Rdirect';
Also seems an problem with lz_ChmHelp/source/lhelpcontrol.pas. at line 196 must be
Result := (fServerOut<>nil) and (fServerOut.ServerID<>'') and (fServerOut.ServerRunning);
Otherwise i have an exception when press F1 (at least for ArchLinux x86_64 CT 5.30 for QT)
Thank you!
CT LAB ver 5.30 11 years 6 months ago #7197
we will test and put your fixes to the Lab CT ver 5.4
PS: we add all your fixes Sir
and pl_Win_MIDI pkg has the same typo, "Source" to "source"
The following user(s) said Thank You: Al
CT LAB ver 5.30 11 years 6 months ago #7206
  • Leslie
  • Leslie's Avatar
Your description of the problem is more presice than mine. Thx.
Last edit: by Leslie.
CT LAB ver 5.30 11 years 4 months ago #7543
  • avra
  • avra's Avatar
DonAlfredo wrote: Installing (any version of) CT on my Windows laptop always fails.
Due to GitHub and GitShell being installed. At least, this is what I think.
They add a path to a directory containing binary tools like make, patch, ....
CTC picks up these binary tools from the path. And fails.
Yoou can try this solution.
