fcllaz.pas fatal error while i build typhonIDE 11 years 11 months ago #6234
  • avra
  • avra's Avatar
I had this same compilation error while trying to install CT 5.10 on my old WinXP SP3 laptop. It seams that I had RM.EXE and MAKE.EXE in path (sources were GIT and WinAVR GCC). I tried BAT script from ZeUsM but then SETUP exits complaining about admin rights. It was nonsense since I am admin. Then I have looked how setup determines if I am admin and it seams that NET command was used for that. Since PATH in ZeUsM script didn't include windows dir, it couldn't find NET command so we had an exit. After adding windows PATH to his script, I had "Remove and Build ALL" fully working with Typhon finally installed. This PATH change in script is temporary and lives only in command line session, so your real PATH is not affected.
@echo off
@set path=c:\codetyphon;c:\codetyphon\fpc\bin\i386-win32;c:\windows;c:\windows\system32
c:
cd c:\codetyphon\
setup.bat
If you want to generalize it you can play with %windir% instead of c:\windows.
@Sternas:
Maybe you could put something like this into your SETUP.BAT? Or change too general RM.EXE, MAKE.EXE and other executables into TYPHON-RM.EXE, TYPHON-MAKE.EXE,...?
UPDATE:
Well, Control center was still using wrong RM.EXE (from my PATH) while trying to build cross elements, so I fixed it in a similar way. Do not call Control Center directly, instead call it from this script:
@start /b c:\codetyphon\binCenter\i386-win32-win32\CodeTyphon.exe
Last edit: by avra.
fcllaz.pas fatal error while i build typhonIDE 11 years 11 months ago #6235
we will try to find a solution
The following user(s) said Thank You: Maximiliano
