indy server with codetyphon problem open on linux. 8 years 11 months ago #7095
  • jose lopez
  • jose lopez's Avatar Topic Author
Hello group members have a problem am using code typhon to create a web application I'm new at this but I used the language as a delphi 7 but the problem is that in typhon I use the INDY component, and Idmappedporttcp I do the code, I compile but I can't run windows application goes well but in linux by opening I start the server closes automatically the server is there any way to be able to fix this thanks
indy server with codetyphon problem open on linux. 8 years 11 months ago #7096
  • Thank you received: 1101
First we move your post to the correct forum session
Forums/Components and Libraries/Networking Development/pl_Indy
Second give us more info about your project
It's a console application or not ?
Your CT version ?
Your Linux OS ?
indy server with codetyphon problem open on linux. 8 years 11 months ago #7097
  • jose lopez
Thanks friend, answering their questions is not a console application is a normal 2 CT is the version most recent to fall this page 5 and the distribution of linux that I'm testing and gives me errors is ubuntu 12.04 lts gives me that error is compiled well but I think the executable Stud ubuntu in this case April attempt to start the server and automatically the program collapses and closes
sorry my bad english
indy server with codetyphon problem open on linux. 8 years 11 months ago #7098
  • jose lopez
yes bro fix my problem
Project > Project Options> Compiler Options>Others>Custom options
Put this into Custom options
-dUseCThreads
ok
And try.
with this command to fix it was in this forum thanks bro
indy server with codetyphon problem open on linux. 8 years 11 months ago #7099
Have fun...
indy server with codetyphon problem open on linux. 8 years 11 months ago #7100
  • jose lopez
thanks for yuo and forum thanks :laugh: :laugh: :laugh: :laugh:
Last edit: by jose lopez. Reason: fixes2
