CodeTyphon 6.30 BigIDE building failed 6 years 2 months ago #11338
  • AMH
  • AMH's Avatar Topic Author
Hi, everybody!
I have been trying to build CodeTyphon 6.30 on Windows7 32bit and I already followed installation instructions after installing DirectX.
the compiler was built successfully, but the building of the BigIDE failed.
I attached the building process log file.
I'm looking for any suggestions about solving this problem.
Thanks in advance.
CodeTyphon 6.30 BigIDE building failed 6 years 2 months ago #11339
  • Thank you received: 1100
please build first Typhon Small IDE
Add the packages you want and rebuild IDE
FPC32 need a lot of memory
The following user(s) said Thank You: AMH
CodeTyphon 6.30 BigIDE building failed 6 years 2 months ago #11340
  • AMH
Sternas Stefanos,
Thank you for your reply
Your suggestion really helped me solve the problem.
There was another problem related to FPC32 since it needs a lot of memory, but I used another computer with more memory to make the new typhon.exe.
I finally managed to build The IDE with much more components.
I attached a screenshot of the IDE.
Thank you very much.
CodeTyphon 6.30 BigIDE building failed 6 years 2 months ago #11341
have fun... :)
