Welcome,
Guest
Installing CT 6.20 on ubuntu 14.04 64 6 years 4 months ago #11103
I get this messages :
Please Wait... Removing Typhon 64 [INFO]: Remove Typhon Directory NOT EXIST, nothing to do ... [INFO]: typhonTemp Directory Removed OK Clean Typhon IDE Setings [INFO]: Clean Typhon64 IDE Setings finish [INFO]: All Typhon parts removed from disk ============================================================== Build FreePascal 64 for Linux ============================================================== [INFO]: FPC64 Source files not exists, extracting... Extract FreePascal From Zip File /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) Extract linux64 Toolchains Library... /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binToolchains/": File o directory non esistente /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binToolchains/": File o directory non esistente Extract Libraries... /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binLibraries/": File o directory non esistente [INFO]: Extract FreePascal source finish [INFO]: FPC64 Binary files not exists, extracting... Install FPC64 Binary Files /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) Clean FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "clean". Arresto. Build FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "all". Arresto. Install FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "install". Arresto. Clean FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "clean". Arresto. Copy FreePascal 64 cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/bin/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/share/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/lib/fpc/3.1.1/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/lib/fpc/*": File o directory non esistente mv: impossibile eseguire stat di "/usr/local/codetyphon/fpc/fpc64/ppcx64": File o directory non esistente ??????????????????????????????????????????????????? [ERROR]: FreePascal 64 NOT build ??????????????????????????????????????????????????? ============================================================== Build Typhon64 Small IDE x86_64-linux-gtk2 for Linux ============================================================== [INFO]: FrePascal NOT exist, start FPC building... ============================================================== Build FreePascal 64 for Linux ============================================================== [INFO]: FPC64 Source files not exists, extracting... Extract FreePascal From Zip File /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) Extract linux64 Toolchains Library... /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binToolchains/": File o directory non esistente /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binToolchains/": File o directory non esistente Extract Libraries... /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) chmod: impossibile accedere a "/usr/local/codetyphon/binLibraries/": File o directory non esistente [INFO]: Extract FreePascal source finish [INFO]: FPC64 Binary files not exists, extracting... Install FPC64 Binary Files /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) Clean FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "clean". Arresto. Build FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "all". Arresto. Install FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "install". Arresto. Clean FreePascal 64 make: *** Nessuna regola per generare l'obiettivo "clean". Arresto. Copy FreePascal 64 cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/bin/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/share/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/lib/fpc/3.1.1/*": File o directory non esistente cp: impossibile eseguire stat di "/usr/local/codetyphon/fpc/newfpc/lib/fpc/*": File o directory non esistente mv: impossibile eseguire stat di "/usr/local/codetyphon/fpc/fpc64/ppcx64": File o directory non esistente ??????????????????????????????????????????????????? [ERROR]: FreePascal 64 NOT build ??????????????????????????????????????????????????? Extract Typhon Source From Zip File /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) [INFO]: Extract Typhon source finish Extract CodeOcean Samples From Zip File /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) /usr/local/codetyphon/binBase/x86_64-linux/7zr: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/codetyphon/binBase/x86_64-linux/7zr) [INFO]: Extract CodeOcean Samples finish Clean Typhon IDE Setings [INFO]: Clean Typhon64 IDE Setings finish Restore Typhon Default IDE Setings [INFO]: Restore Typhon64 Settings finish make: *** Nessuna regola per generare l'obiettivo "all". Arresto. mv: impossibile eseguire stat di "typhon": File o directory non esistente mv: impossibile eseguire stat di "typhonstart": File o directory non esistente mv: impossibile eseguire stat di "typhonbuild": File o directory non esistente mv: impossibile eseguire stat di "tools/ctres": File o directory non esistente mv: impossibile eseguire stat di "tools/ctlrstofrm": File o directory non esistente [INFO]: Clean Tools Directory find: "/usr/local/codetyphon/typhon/tools": File o directory non esistente find: "/usr/local/codetyphon/typhon/tools": File o directory non esistente ?????????????????????????????????????????????????????????? [ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build ?????????????????????????????????????????????????????????? ============================================================== Build Typhon64 BIG IDE x86_64-linux-gtk2 for Linux ============================================================== [ERROR]: Sorry, Typhon64 from Small-IDE NOT Build please remove and build Typhon again... ==================================================== CodeTyphon Studio 6.20 Setup for Linux64 Settings: Platform=gtk2 Multiarch Mode=0 ==================================================== 0) Install System Libraries 1) Run CodeTyphon Center (CTC) 11) -- Platform (widget) Setup 12) -- Multi-Architecture Setup 3) Remove FreePascal 4) Remove and Build FreePascal 5) Remove Typhon IDE 6) Remove and Build Typhon IDE 7) Remove ALL 8) Remove and Build ALL 9) EXIT >>> Select an action (press 0..9 key): 1 ./setup.sh: riga 543: ./codetyphon: File o directory non esistente |
Installing CT 6.20 on ubuntu 14.04 64 6 years 4 months ago #11104
our suggestion is: a)- install p7zip sudo apt-get install p7zip b)- install CT6.3 CT6.30 has the latest p7zip, this version of p7zip works only with the new Linux Kernels (>4.2) CT will use the local copy of p7zip if exists. PS : Ubuntu 14.04 64 is very very old Distribution (Release date 17 April 2014).... PilotLogic Architect and Core Programmer
Installing CT 6.20 on ubuntu 14.04 64 6 years 3 months ago #11157
Tank you, following your advice I solved the problem
