Problem with gradient in the brush editor ORCA2D 6 years 4 weeks ago #11540
  • Jean-Philippe FABRE
  • Jean-Philippe FABRE's Avatar Topic Author
In the brush editor form il you choose gradient, the start point or the end point can be deleted
then you have only one point to draw the gradient so it becomes unusable.
I believe that it can be fixed in the orcad2_scene.pas:
procedure TD2GradientEdit.MouseUp(Button:TMouseButton; Shift:TShiftState; X,Y:single);
by changing the line 34495:
if (Y > Height + 10) and (FGradient.Points.Count > 1) then ....
to
if (Y > Height + 10) and (FGradient.Points.Count > 2) then....
Problem with gradient in the brush editor ORCA2D 6 years 4 weeks ago #11541
  • Thank you received: 1100
we add your fix to Lab CT 6.50
