ORCA library 10 years 3 months ago #5021
  • Marko
  • Marko's Avatar
Hi guys,
Ive just downloaded 4.70 version and tried the orca 2d compilation for arm linux, with raspi librari.
Im getting this errors:
"Compiling package LazControls 1.0.1" completed
"Compiling package IDEIntf 1.0" completed
"Compiling package pl_orca 4.0.1" completed
ctrlsdemo.lpr(16) Warning: "crti.o" not found, this will probably cause a linking failure
ctrlsdemo.lpr(16) Warning: "crtbegin.o" not found, this will probably cause a linking failure
ctrlsdemo.lpr(16) Warning: "crtend.o" not found, this will probably cause a linking failure
ctrlsdemo.lpr(16) Warning: "crtn.o" not found, this will probably cause a linking failure
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: warning: C:\codetyphon\CodeOcean\ORCA\samples\xbin\link.res contains output sections; did you forget -T?
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: cannot find -lpangocairo-1.0
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: cannot find -lm
ctrlsdemo.lpr(16) Error: Error while linking
ctrlsdemo.lpr(16) Fatal: There were 1 errors compiling module, stopping
Ive properly included raspi libs in project (c:\codetyphon\binLibraries\arm-linux-pi\), but in raspi folder i could not find mentioned libs.
Am i missing something?
Thanks.
ORCA library 10 years 3 months ago #5022
  • Thank you received: 1101
Yes Sir
libpangocairo-1.0.so and Libm.so are not in our arm-linux-pi.7z
We will update arm-linux-pi library soon...
ORCA library 10 years 3 months ago #5032
  • Marko
  • Marko's Avatar
Hi Sternas,
Thanks on prompt answer, Im eager to test the orca 2d on my board, so i will check daily on this release.
Do you also have some guide how to make the library package for CT?
Thanks.
Marko
ORCA library 10 years 3 months ago #5033
Look here Sir
You need run-time libraries (*.so) from raspi OS
These are shared Libraries and not Links to shared Libraries.
For sample the libc.so links to shared library libc.so.7 We get libc.so.7 and rename to libc.so
ORCA library 10 years 3 months ago #5045
  • Marko
  • Marko's Avatar
Hi ive followed the instructions provided but now im getting this messages. I believe it something with compiling options.. What im missing here..? Should i recompile all libraries on my raspberry for EABI 0 or can i recompile the stuffs in CT for EABI 5?
Thanks.
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\system.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\system.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazconfigstorage.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazconfigstorage.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazutf8classes.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazutf8classes.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\fcl-base\syncobjs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\fcl-base\syncobjs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\fcl-process\process.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\fcl-process\process.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\fcl-process\pipes.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\fcl-process\pipes.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\termio.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\termio.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wslclclasses.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wslclclasses.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsimglist.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsimglist.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsproc.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsproc.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\propertystorage.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\propertystorage.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wscontrols.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wscontrols.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsforms.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsforms.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\cwstring.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\cwstring.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\initc.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\initc.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\dynlibs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\dynlibs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\unixcp.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\unixcp.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\rtl\dl.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\rtl\dl.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2disableliboverlay.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2disableliboverlay.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2int.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2int.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\x11\xlib.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\x11\xlib.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\x11\x.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\x11\x.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2x.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2x.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\dialogs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\dialogs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\dynhasharray.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\dynhasharray.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\buttons.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\buttons.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\stdctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\stdctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\checklst.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\checklst.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\comctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\comctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\spin.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\spin.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\extctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\extctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2pixbuf.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2pixbuf.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\gtk2.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\gtk2.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\gdk2.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\glib2.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\glib2.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\pango.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\pango.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2winapiwindow.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2winapiwindow.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2globals.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2globals.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2proc.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2proc.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2def.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2def.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2fontcache.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2fontcache.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2extra.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2extra.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2msgqueue.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2msgqueue.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\x11\xrender.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\x11\xrender.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\cairo\cairo.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\cairo\cairo.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\buttonpanel.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\buttonpanel.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\imagelistcache.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\imagelistcache.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\popupnotifier.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\popupnotifier.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsextctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsextctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsdialogs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsdialogs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wschecklst.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wschecklst.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\toolwin.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\toolwin.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wscomctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wscomctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wstoolwin.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wstoolwin.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsspin.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsspin.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\atk.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\atk.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\gtk2\gtk2ext.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\gtk2\gtk2ext.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\extdlgs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\extdlgs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2debug.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2debug.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\lclmessageglue.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\lclmessageglue.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\calendar.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\calendar.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wscalendar.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wscalendar.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\wsextdlgs.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\wsextdlgs.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\lclmemmanager.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\lclmemmanager.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsprivate.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsprivate.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\fpc\units\arm-linux\fcl-base\uriparser.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\fpc\units\arm-linux\fcl-base\uriparser.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wscontrols.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wscontrols.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\lazlinkedlist.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\lazlinkedlist.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsfactory.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsfactory.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsstdctrls.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wsstdctrls.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wschecklst.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2wschecklst.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2themes.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\gtk2\gtk2themes.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\grids.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\grids.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\pairsplitter.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\pairsplitter.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\dynamicarray.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\dynamicarray.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\lcl\units\arm-linux\maskedit.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\lcl\units\arm-linux\maskedit.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlcfg.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlcfg.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazfilecache.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazfilecache.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_dom.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_dom.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlread.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlread.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlwrite.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\laz2_xmlwrite.o
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: error: Source object C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazdbglog.o has EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5
c:\codetyphon\fpc\bin\i386-win32\arm-linux-ld.exe: failed to merge target specific data of file C:\codetyphon\typhon\components\lazutils\lib\arm-linux\lazdbglog.o
IM using raspi v.B and latest debian version/.
Last edit: by Marko.
ORCA library 10 years 3 months ago #5046
EABI 0 for all
please read the tutorial here
ORCA library 10 years 2 months ago #5160
  • Marko
  • Marko's Avatar
Hi all,
Ive tried but same error appearing. I salvaged the libs from debian lib folder, and rename links as described.
What are the steps to make this working:
- should i recompile the whole kernel and debian to be eabi 0?
- or there is other trick that can solve this EABI version 0, but target C:\codetyphon\CodeOcean\ORCA\samples\xbin\ctrlsdemo has EABI version 5?
- or?
Note: if i understood good, the libs are compiled for eabi0 but my target is eabi5, is there any way how i can setup my project to be compiled for eabi0, maybe this is the issue?
Im trying to compile c:\codetyphon\CodeOcean\ORCA\samples\ctrlsdemo\
Thanks.
ORCA library 10 years 2 months ago #5161
If your arm target OS is EABI version 5, please use
win32-arm-linux-eabi5-7z toolchain
ORCA library request and :
libm.so
libgtkglext-x11-1.0.so
libgdkglext-x11-1.0.so
libraries to your Arm Target OS
ORCA library 7 years 1 month ago #10576
  • Jacek
  • Jacek's Avatar
Is ORCA 2D support Android now or is some future plan ?
Last edit: by Jacek.
ORCA library 7 years 1 month ago #10577
No Sir
ORCA 2D not support android, yet
and we don't have any plans for this, yet
