RxDBGrid prolem 6 years 1 month ago #11465
  • Nicola
  • Nicola's Avatar Topic Author
In RxDBGrid in design time the dgTabs option is set to false and can only be changed in the code. Looking at the RxDBGrid source, the first lines of the Create constructor are as follows:
constructor TRxDBGrid.Create(AOwner: TComponent);
  FFooterOptions:=TRxDBGridFooterOptions.Create(Self);
  inherited Create(AOwner);
{$IFDEF RXDBGRID_OPTIONS_WO_CANCEL_ON_EXIT}
  Options := Options - [dgCancelOnExit];
{$ENDIF}
  FSaveOnDataSetScrolled:=Datalink.OnDataSetScrolled;
  Datalink.OnDataSetScrolled:=@OnDataSetScrolled;
  FToolsList:=TFPList.Create;
  FColumnDefValues:=TRxDBGridColumnDefValues.Create(Self);
  FSearchOptions:=TRxDBGridSearchOptions.Create(Self);
  FSortColumns:=TRxDbGridColumnsSortList.Create;
  FGroupItems:=TColumnGroupItems.Create(Self);
  F_MenuBMP := CreateResBitmap('rx_menu_grid');
  Options := Options - [dgTabs];          <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
//  TDrawGrid(Self).Options:=TDrawGrid(Self).Options + [goColSpanning];
  OptionsRx := OptionsRx + [rdgAllowColumnsForm, rdgAllowDialogFind, rdgAllowQuickFilter];
Is there any reason I do not understand why the option is set to False?
RxDBGrid prolem 6 years 1 month ago #11467
  • Thank you received: 1101
we will test this tomorrow and I will report here
RxDBGrid prolem 6 years 1 month ago #11468
It's a programming Option Sir
to set "dgTabs" in TRxDBGrid.Create not as option of TRxDBGrid
RxDBGrid prolem 6 years 1 month ago #11482
  • Nicola
Ok,
thanks for your quick reply
