[LAB] Cindy components 11 years 9 months ago #2213
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
RockyLuck wrote: @Viking: your assumption that the message to catch was CN_DRAWITEM was understandable, probably this should have happened, but it was not correct. This is the code for handling the WM_DRAWITEM in function WIndowProc (file Win32callback.inc):
I just had another quick look at pl_Cindy package.
More CN* and CM* messages are incorrectly translated as LM* messages! Some inherited calls that are required are commented out. I would start from there.
I installed CT on Windows 7 x64 in VirtualBox so I can check some of the samples there.
Would you please compile some of the samples included in CodeOcean with Delphi and post some screenshots? I need to see how those components should look when work properly in order to try to fix them.
[LAB] Cindy components 11 years 9 months ago #2214
  • RockyLuck
  • RockyLuck's Avatar
viking wrote: More CN* and CM* messages are incorrectly translated as LM* messages!
They are only translated "incorrectly" because Lazarus does not correctly translate them into CN messages. That's no fault on behalf of the pl_Cindy package.
This is the image of the cyAdvButton demo when compiled with Delphi 7:
Hope this helps :unsure:
Last edit: by RockyLuck.
[LAB] Cindy components 11 years 9 months ago #2220
  • Aleksandar
I was talking about wrong code conversions done by someone from CT team while converting Cindy to Lazarus.
I was talking about things like this:
For example in cyBaseSpeedButton.pas
there is
procedure CMMouseEnter(var Message: TLMessage); message LM_MOUSEENTER;
instead of
procedure CMMouseEnter(var Message: TLMessage); message CM_MOUSEENTER;
Also
procedure CMMouseLeave(var Message: TLMessage); message LM_MOUSELEAVE;
instead of
procedure CMMouseLeave(var Message: TLMessage); message CM_MOUSELEAVE;
In
procedure TcyBaseSpeedButton.CMMouseEnter(var Message: TLMessage);
Inherited; is commented, but it is needed there.
... and so on.
RockyLuck wrote: This is the image of the cyAdvButton demo when compiled with Delphi 7:
Thank you. That is what I was looking for.
Last edit: by Aleksandar.
[LAB] Cindy components 11 years 9 months ago #2223
  • Thank you received: 1100
we will fix these problems
[LAB] Cindy components 11 years 9 months ago #2225
  • Aleksandar
sternas wrote: Thanks Sir
I do no use those components, so I only write about things that I noticed while checking what is done. I also would suggest to convert latest version, since I also noticed that this is not the latest version.
I am not sure that those changes that I mentioned will make all components work like in Delphi, but I hope that at least some of them will start to work better (or even as they planed to work).
[LAB] Cindy components 11 years 9 months ago #2230
  • Mauricio
  • Mauricio's Avatar
  • Thank you received: 7
Cindy v5.03 released!
Added TcyBook component:
https://sourceforge.net/projects/tcycomponents/screenshots/328505
Virtual book with turn page effect (perfect for android devices), page rendering etc ...
Also added TcyBook and TcyDebug demo.
Mauricio
[LAB] Cindy components 11 years 9 months ago #2233
We port ver 5.0.3 on windows
now we must solve some graphic problems (cyGraphics.pas)
more news later...
and large image
[LAB] Cindy components 11 years 9 months ago #2234
Port of ver 5.0.3 on Wince finish
(CodeTyphon crossbuild Ability)
Emulator with Windows Mobile 6.5.3
and big image
[LAB] Cindy components 11 years 9 months ago #2235
Port of ver 5.0.3 on Solaris/OpenIndiana 64 finish
CodeTyphon Studio Power...
tomorrow Linux and FreeBSD ports
and big image
[LAB] Cindy components 11 years 9 months ago #2236
  • felixsg
  • felixsg's Avatar
what are the ETA for 2.80?
[LAB] Cindy components 11 years 9 months ago #2237
ETA for ver 2.80, 5-6 days
if all lab tests are OK
[LAB] Cindy components 11 years 9 months ago #2240
  • RockyLuck
sternas wrote: Sir
1. What about the glyph problem for some buttons as reported in this thread?
2. Can you tell which Cindy components will only work on Windows systems?
[LAB] Cindy components 11 years 9 months ago #2242
Our opinion is that, these are small problems.
Please don't forget that
CodeTyphon Studio is a free project
and it's not a company product, we don't have customers...
We have friends with the same passion: Pascal Programming
we have friends with the same vision:
to create a Pascal Programming Platform (CT),
which will be the most powerful Programming Studio on this planet
And we also believe it's NOT a dream anymore...
With this philosophy, some errors will exist.
and we can work together to solve these issues.
Have fun...
[LAB] Cindy components 11 years 9 months ago #2243
  • felixsg
  • felixsg's Avatar
Thank's by all
If I remenber well I use Pascal the first time with delphi 2
I try to help you sometime in the future
[LAB] Cindy components 11 years 9 months ago #2246
  • RockyLuck
sternas wrote: Sir
I understand that. The questions were not meant as criticism. They were just questions ;)
The cyAdvButton problem is not a small problem, if you want to use the cyAdvButton in a project. It just does not work. Again: no criticism, just an observation.
The question to be able to plan my projects: is that problem solved in release 2.80?
Which brought me to the next question: which packages or which components are not portable? In the current state, the cyAdvButton is not portable, because the WM_DRAWITEM message is not provided by the Linux implementations of Lazarus. If I want to produce a completely portable program, which components should I avoid?
Maybe, in the Lazarus' components directory, in the next release, you could add a file to describe that. :unsure:
sternas wrote: With this philosophy, some errors will exist.
I agree and I did: I already supported you guys by providing the missing skins for the Lava package.
It's just that the cyAdvButton problem is too complicated for me.
Regards ;-}
Dick
[LAB] Cindy components 11 years 9 months ago #2255
  • Mauricio
  • Mauricio's Avatar
Cindy V5.05 released!
Big improvments (speed up using windows gdi) made in TcyBook component!
Cindy components V5.05
15/07/2012 - cyBook.pas - We can see now page behind on the turn page effect!
14/07/2012 - cyBook.pas - Small bugs fixed + improvments
14/07/2012 - cyBook.pas - Despite it is not coherent in real book, we can set page with odd (1,3,5 etc ...) numbers to CurrentLeftPage property
13/07/2012 - cyBook.pas - Added TTurnPageAnimation.DoubleBuffered: Boolean property
13/07/2012 - cyBook.pas - Replaced use of BitmapResize() that is too low by DrawCanvas()
12/07/2012 - cyBook.pas - Removed prFitMediumQuality and prStretchMediumQuality to TPageRender
12/07/2012 - cyBook.pas - Modified BeforePreparePage event in order to able custom page rendering or/and use external page resizing engine.
12/07/2012 - cyBook.pas - Added OnLeftPageClick and OnRightPageClick events
12/07/2012 - cyProgressionPanel.pas - Added property State to public declaration
12/07/2012 - cyAdvProgressionPanel.pas - Small bug fixed on .Open procedure (avoid error if we call several times open();)
12/07/2012 - cyAdvProgressionPanel.pas - Added property State to public declaration
11/07/2012 - cyBook.pas - Some optimization and added read/write property access to TBookPageView (for exemple TBookPageView.Page: TBitmap)
11/07/2012 - cyBook.pas - Turn page with mouse if page dragged and not clicked
11/07/2012 - cyBook.pas - Added DblClick event
11/07/2012 - cyBook.pas - Added boFitSmallImages and boStretchSmallImages to Options
Regards,
Mauricio
[LAB] Cindy components 11 years 9 months ago #2256
ver 5.05 port finish
STRETCH_HALFTONE not exist to LCL, I use HALFTONE
I think now cybook is OK
[LAB] Cindy components 11 years 9 months ago #2257
  • Mauricio
  • Mauricio's Avatar
I have changed to HALFTONE myself after checking that quality is the same.
"I think now cybook is OK "
You bet!
Regards,
Mauricio
[LAB] Cindy components 11 years 7 months ago #2512
  • RockyLuck
There's a couple of bugs in cyAdvSpeedButton.pas. The bugs are all of the same nature: if a test is made against the State of the TcyAdvSpeedButton the state "bsHot" is always forgotten, resulting in an exception as soon as the cursor hovers over such a button.
The bugs can be fixed as follows:
Lines 408-409: case FState of bsUp {Add this:}, bsHot: {this one is less important}
Lines 493-494: case aState of bsUp {Add this:}, bsHot:
Lines 578-579: case aState of bsUp {Add this:}, bsHot:
Especially the last two generate an exception because the RenderProp, resp. PaintButton are not assigned!
This bug was already reported in #2094
The same bug would surface in cyAdvButton in the DrawButton and DrawBackground procedures, but these procedures are never called, because of the other bug ( #1796 ) which has been declared minor ( #2242 ):sick: (although the cyAdvButton is completely useless because of it). :S
[LAB] Cindy components 11 years 7 months ago #2513
we added your fixes
after 6 months you found the problem
Same problem:
cySpeedButton.pas
line 314
line 374
cyBitBtn.pas
line 208
line 347
cyGraphics.pas
line 861
updated source
