Not clear close the program!!! problem IDE?! 6 years 6 months ago #11046
  • Tigr
  • Tigr's Avatar Topic Author
When performing a simple task, namely filling a three-dimensional array, the program suddenly for no reason just destroyed....( CT 6.2
mas:array[1..2097151,1..2097151,1..2097151] of integer;
var i,j,k:integer;
for i:=1 to 2097151 do
for j:=1 to 2097151 do
for k:=1 to 2097151 do
mas[i,j,k]:=1;
form1.Memo1.Lines.Add('dfbdfbdb');
Last edit: by Tigr.
Not clear close the program!!! problem IDE?! 6 years 6 months ago #11047
  • Tigr
after restarting the program from the environment .... there is a bug:
failed to execute:193
Not clear close the program!!! problem IDE?! 6 years 6 months ago #11048
  • Thank you received: 1100
don't use so big numbers (2097151) in multi dimension arrays
wiki.freepascal.org/Integer
this sample work OK
  mas: array[1..100, 1..100, 1..100] of integer;
  i, j, k: integer;
  for i := 1 to 100 do
    for j := 1 to 100 do
      for k := 1 to 100 do
        mas[i, j, k] := 1;
Not clear close the program!!! problem IDE?! 6 years 6 months ago #11049
  • Tigr
Thank you! I'm just under forgot for a moment that program need a lot of memory!
when I'm on the calculator counted realized what a fool!
Last edit: by Tigr.
Not clear close the program!!! problem IDE?! 6 years 6 months ago #11050
have fun...:)
