Logarithmic scale in TAChart 7 years 1 month ago #10590
  • Premysl Beran
  • Premysl Beran's Avatar Topic Author
Hello there,
I just tried to use the logarithmic scale on Y axis for one of my project. In the design-time the setting of the transformation works quite fine. I see the changes on the axis. But when I load the data and then turn on logarithmic scale I get error saying Floating Point Overload.
In attachment you will find simple test with code and also compiled executable.
Thanks for help
With best regards
Premek
File Name: ChartLogTest.zip
File Size:1,583 KB
Last edit: by Premysl Beran.
Logarithmic scale in TAChart 7 years 1 month ago #10591
  • Premysl Beran
My mistake. It was not completely clear to me. Each serie in the chart have to have parameter AxisIndexX and AxisIndexY adjusted (default is -1) when you want to use the transformational. So it works now. B)
