Question CT LAB ver 6.80
1 month 1 day ago #13343 by Matis A.
Replied by Matis A. on topic CT LAB ver 6.80
We try hard to solve debugging problems
Try to use and
FpDebugger or
LLDB Debugger
more info
1 month 1 day ago - 1 month 1 day ago #13344 by Rafał
Replied by Rafał on topic CT LAB ver 6.80
I have same situation with debugger. I try few projects.
Same result: External SIGSEGV,
fpDebugger : External: Access violation
LLDB Debugger: Working, OK.
Last edit: 1 month 1 day ago by Rafał.
1 month 1 day ago #13345 by Matis A.
for the report
1 month 1 day ago #13346 by Peter Heckert
Replied by Peter Heckert on topic CT LAB ver 6.80
If this is a 32 Bit Problem, then this could help:
If the type of debugging info is set to "default" or "automatic" then the 32 bit FPC compiler produces Stabs debugging info.
(It shouldnt, because Stabs is deprecated but it does)
So the debugging info for the project should be explicitely set to "Dwarf with sets".
This is true for FPC 3.0.4 32 bit and so far I have seen, it is also true for FPC 3.3.1 32 bit.
1 month 1 day ago #13347 by Matis A.
we must try that
1 month 20 hours ago #13348 by Rafał
I tried what Peter Heckert mentioned.
I changed In Project Options -> Debugger -> Debugger Info -> Debugger Format Code from "Automatic" to "Dwarf with sets" and it's working.
There is no errors.
I tried it on few projects.
1 month 18 hours ago #13349 by Matis A.
The same here
1 month 11 hours ago - 1 month 11 hours ago #13350 by Sternas Stefanos
Replied by Sternas Stefanos on topic CT LAB ver 6.80
For the next
LAB CT release we add some new things
-COSMIC 1: Switch "Automatic" Project "Type of Debug info"
to "Dwarf2 with sets" (-gw2 -godwarfsets)
Now all supported by Typhon IDE Debuggers can run without
change working Project Debug Options
-COSMIC 2: Add to Typhon IDE support for DWARF 4 Debugging Format Standard
For testing...
Last edit: 1 month 11 hours ago by Sternas Stefanos.
The following user(s) said Thank You: xcod, Fernando
