CT 4.50 10 years 7 months ago #4462
  • opc0de
  • opc0de's Avatar Topic Author
When is CT 4.50 arriving ?
Can't wait...
CT 4.50 10 years 7 months ago #4463
  • ExDatis
  • ExDatis's Avatar
I guess that the team deserved rest and relaxation, don't push please...
CT 4.50 10 years 7 months ago #4471
  • Thank you received: 1100
We preparing CodeTyphon ver 4.50
ETA 3-4 days
Your suggestions guys
The following user(s) said Thank You: ExDatis, FredyCC, kenlee
CT 4.50 10 years 7 months ago #4472
  • DiMiTRiOS
  • DiMiTRiOS's Avatar
CnPack IDE Wizards !!!
AI can not win the natural stupidity
CT 4.50 10 years 7 months ago #4473
  • Aleksandar
  • Aleksandar's Avatar
  • Thank you received: 31
You might want to add NHunspell. It's open source component to implement spell checking using OpenOffice 3 dictionaries.
sourceforge.net/projects/nhunspelldelphi/files/
If there is too much work, then you may leave it for next version.
CT 4.50 10 years 7 months ago #4474
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
is proposed:
TMultiDoc : the main form docking area.
TChildDoc : the child container with resizeable border and button.
www.pilotlogic.com/sitejoom/index.php/fo...mdiform-and-mdichild
thank you!
CT 4.50 10 years 7 months ago #4483
  • zeljko
  • zeljko's Avatar
add component:
IBX For Lazarus (Firebird Express)
www.mwasoftware.co.uk/index.php?option=c...ew&id=102&Itemid=133
CT 4.50 10 years 7 months ago #4484
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
Problems with CT 4.5?
CT 4.50 10 years 7 months ago #4485
No Sir
we are in final tests...
The following user(s) said Thank You: Miquel Matas, Rain, ExDatis, FredyCC, zeljko, zbyna, Michal
CT 4.50 10 years 7 months ago #4490
  • atlandev.ct
  • atlandev.ct's Avatar
I see that on web today. that seem very promising, isn't it?
Native Controls for android
blog.naver.com/PostView.nhn?blogId=simon...=false&from=postView
CT 4.50 10 years 6 months ago #4491
  • Rain
  • Rain's Avatar
And I see that on web today: 4.50 is born !
www.pilotlogic.com/codetyphon/changeslog.txt
Thanx to the pilot team !
CT 4.50 10 years 6 months ago #4492
Have fun, we waiting for your report
Oh, Ex-Mil-Pilot (after 27 years...)
The following user(s) said Thank You: Michal
CT 4.50 10 years 6 months ago #4493
  • DiMiTRiOS
Symantec Endpoint Protection shows
Bloodhound.MalPE
Anyone with this problem ???
CT 4.50 10 years 6 months ago #4505
  • ExDatis
  • ExDatis's Avatar
CT 4.50
Good work! Thank you very much!
p.s. test win7 32bit ultimate
CT 4.50 10 years 6 months ago #4506
have fun
CT 4.50 10 years 6 months ago #4507
  • gulyone
  • gulyone's Avatar
  • Thank you received: 5
actually found CT 4.5 working "F"ine on Ubuntu 12.04 LTS (Long time Support stable) and on Windows 7 64 bits.
I just want to put a little question that isn't clear to me :
why does CT build his amazing and great IDE on unstable versions of FPK compiler ? I really don't get it.
I tried to rebuild CT with a stable release of FPK (actually 2.6.0) but scripts aborted
I think that if CT team provided an IDE based on stable FPC compiler releases, they would likely earn better worldwide fame. Especially with professionnal developpers they target
Last edit: by gulyone.
CT 4.50 10 years 6 months ago #4509
we want to be one step ahead, always
and we make tests before every CT release.
We select FPC SVN revision from these tests.
Don't forget our "lab test circle":
Win32=>Win64=>Linux32=>Linux64=>FreeBSD32=>FreeBSD64=>Solaris32=>Solaris64
Linux32-QT=>Linux64-QT=>Cross-WinCE=>Cross-Android->etc.
The team for these "lab test circle": 10 programmers with 25 PC.
We start "lab test circle" every Friday in-order to keep
LAB CodeTyphon version always releasable (hot)
We mark every success pass of "lab test circle" for FPC SVN revision
Our "Vision and Reality":CodeTyphon is the FREE Professional Programming Tool
CT 4.50 10 years 6 months ago #4514
  • sam
  • sam's Avatar
I agree.
fpc 2.7.1 is not stable yet.
The attached example works fine with 2.6.x, but not with 2.7.1
File Name: 0024853_im...ample.7z
File Size:90 KB
CT 4.50 10 years 6 months ago #4521
  • zeljko
  • zeljko's Avatar
xubuntu 13.04 64bit
Install CodeTyphon 4.5 BigID - ok
QT4Pas install - ok
compile Linux 64 bit - compile (test linux xubuntu 64 - WORK)
compile Linux 32 cross (add i386-linux) - compile (test linux xubuntu 64 - WORK)
compile Win 64 cross (LCLWidgetType=qtk2) - compile (not test)
compile win 32 cross (LCLWidgetType-qtk2) - compile (not test)
add toolchains arm-wince
compile arm-wince (LCLWidgetType=wince) - compile (test pocket-PC "Fujitsu Simens" - WORK)
PROBLEMS:
compile arm-linux cross (add arm-linux-pi) - compile (test "beaglebone black" NOT WORK - No such file or directory- Lazarus board beaglebone black work)
(HELP!)
Visual indy component TIdHTTPServer add to Form - code typhon problems
(HELP!)
Last edit: by zeljko.
CT 4.50 10 years 6 months ago #4522
  • Rain
  • Rain's Avatar
@ sam
Interestingly, Your provided example works without the described error with this FPC 2.7.1 "Rev 24744, with Modification":
02-Jun-2013 ver 4.30
Typhon IDE 4.3.0 Synchronize with Lazarus Source SVN 01-06-2013 Rev 41480.
FreePascal 2.7.1 Source from SVN 01-06-2013 Rev 24744, with Modification.
The later ones are indeed faulty.
Would be interesting, what the modification was.
