CrossBuild Win32-MacOS 5 years 11 months ago #11656
  • Md. Shariful Alam Khan
Can any one please guide me step by step for CrossBuild Win32->MacOS(Sierra, High Sierra)?
CrossBuild Win32-MacOS 5 years 11 months ago #11657
  • Thank you received: 1101
We have problem with MacOS and Solaris OS as crossbuild targets.
We don't provide "System Libraries" for these OSes,
it's OS license subject
If you find "System Libraries" for MacOS (and Solaris OS)
the cross build procedure is the same like any other crossbuild target
PS: Windows OS as crossbuild target from Unix Host don't need "System Libraries".
CrossBuild Win32-MacOS 5 years 7 months ago #12681
  • Premysl Beran
  • Premysl Beran's Avatar
Hi Sternas,
I found the ToolChain for the Win to MacOS on the server. So, I downloaded and tried to compile. The first step finished with success. I have all the x86_64(i386)-darwin-*.exe files. But the second and third steps finish with error (see below). The error occurred when x86_64(i386)-darwin-clang.exe was not found. It seems it is not related to the system libraries. These are needed for linking when compiling the executable. How can I solve this problem?
Thanks for the help.
With best regards
Premek
CT6.4, Win10
[INFO]: !!! Cross compiler Executable ppcross386.exe for win32, Build OK. !!!
       Stage 2: Build All Units and Packages
C:/codetyphon/fpc/fpc32/bin/i386-win32/make -C rtl all
make[1]: Entering directory 'C:/codetyphon/fpcsrc/rtl'
C:/codetyphon/fpc/fpc32/bin/i386-win32/make -C darwin all
make[2]: Entering directory 'C:/codetyphon/fpcsrc/rtl/darwin'
C:/codetyphon/fpc/fpc32/bin/i386-win32/gmkdir.exe -p C:/codetyphon/fpcsrc/rtl/units/i386-darwin
ppcross386.exe -dNOMOUSE -Ur -dFPC_USE_LIBC -Tdarwin -XPi386-darwin- -Xr -Ur -Xs -O2 -n -Fi../inc -Fi../i386 -Fi../unix -Fi../bsd -Fi../bsd/i386 -Fi../darwin/i386 -FE. -FUC:/codetyphon/fpcsrc/rtl/units/i386-darwin -di386 -dRELEASE  -Us -Sg ../bsd/system
system.pp(387) Error: Assembler i386-darwin-clang.exe not found, switching to external assembling
system.pp(387) Fatal: There were 1 errors compiling module, stopping
Fatal: Compilation aborted
make[2]: *** [Makefile:2863: system.ppu] Error 1
make[2]: Leaving directory 'C:/codetyphon/fpcsrc/rtl/darwin'
make[1]: *** [Makefile:2511: darwin_all] Error 2
make[1]: Leaving directory 'C:/codetyphon/fpcsrc/rtl'
make: *** [Makefile:2606: rtl] Error 2
       Stage 3: Install All Units and Packages
C:/codetyphon/fpc/fpc32/bin/i386-win32/make -C rtl install
make: *** [Makefile:2580: rtl_install] Error 2
CrossBuild Win32-MacOS 5 years 7 months ago #12683
1) i386-darwin-clang.exe don't exits in your OS Libraries
you must find this file.
2) My suggestion is to try and LAB CT 6.6, has better MacOS support
CrossBuild Win32-MacOS 5 years 7 months ago #12685
  • Premysl Beran
1) I suppose that the file "i386-darwin-clang.exe" should be created during the first stage of CrossBuild ToolChain. Or it is a part of the windows system? It should have the *.exe extension, so it is not related with MacOS libraries. I searched for it in the whole Windows system disk and I didn't find it.
2) I just tried it with CT 6560 and I've got the same problem. Not able to cross-build this ToolChain.
