Wiki
Pascal - File Handling
Locked
User Rating: 0 / 5
Star InactiveStar InactiveStar InactiveStar InactiveStar Inactive
Contents[Hide]
Pascal treats a file as a sequence of components which must be of uniform type. A file's type is determined by the type of the components. File data type is defined as:
type
file-name = file of base-type;
Where, the base-type indicates the type of the components of the file. The base type could be anything like, integer, real, Boolean, enumerated, subrange, record, arrays and sets except another file type. Variables of a file type are created using the var declaration:
f1, f2,...: file-name;
Following are some examples of defining some file types and file variables:
type
   rfile = file of real;
   ifile = file of integer;
   bfile = file of boolean;
   datafile = file of record
   arrfile = file of array[1..4] of integer;
   marks: arrfile;
   studentdata: datafile;
   rainfalldata: rfile;
   tempdata: ifile;
   choices: bfile;
1. Creating and Writing to a File
Let us write a program that would create a data file for students' records. It would create a file named students.dat and write a student's data into it:
program DataFiles;
type
   StudentRecord=Record
      s_name:AnsiString;
      s_addr:AnsiString;
      s_batchcode:AnsiString;
   Student:StudentRecord;
   f: file;
   AssignFile(f,'students.dat');
   Rewrite(f);
   Student.s_name :='John Smith';
   Student.s_addr :='United States of America';
   Student.s_batchcode :='Computer Science';
   BlockWrite(f,Student,sizeof(StudentRecord));
   CloseFile(f);
end.
When compiled and run, the program would create a file named students.dat into the working directory. You can open the file using a text editor, like notepad, to look at John Smith's data.
2. Reading from a File
We have just created and written into a file named students.dat. Now let us write a program that would read the student's data from the file:
program DataFiles;
type
      s_name:AnsiString;
      s_addr:AnsiString;
   f: file;
   reset(f);
   while not eof(f) do
      Blockread(f,Student,sizeof(StudentRecord));
      writeln('Name: ',Student.s_name);
      writeln('Address: ',Student.s_addr);
      writeln('Batch Code: ',Student.s_batchcode);
   readln;       // to see the output
   closeFile(f);
end.
Address: United States of America
Batch Code: Computer Science
3. Files as Subprogram Parameter
Pascal allows file variables to be used as parameters in standard and user defined subprograms. The following example illustrates this concept. The program creates a file named rainfall.txt, and stores some rainfall data. Next, it opens the file, reads the data and computes the average rainfall.
Please note that, if you use a file parameter with subprograms, it must be declared as a var parameter.
program addFiledata;
const
   MAX =4;
type
   raindata = file of real;
   rainfile: raindata;
   filename:ShortString;
procedure writedata(var f: raindata);
   data: real;
   i: integer;
   rewrite(f,sizeof(data));
   for i:=1 to MAX do
      writeln('Enter rainfall data: ');
      readln(data);
      write(f, data);
   closeFile(f);
procedure computeAverage(var x: raindata);
   d, sum: real;
   average: real;
   reset(x);
   sum:=0.0;
   while not eof(x) do
      read(x, d);
      sum := sum + d;
   average := sum/MAX;
   CloseFile(x);
   writeln('Average Rainfall: ', average:7:2);
   writeln('Enter the File Name: ');
   readln(filename);
   AssignFile(rainfile, filename);
   writedata(rainfile);
   computeAverage(rainfile);
end.
rainfall.txt
34
45
56
78
Average Rainfall: 53.25
4. Text Files
A text file, in Pascal, consists of lines of characters where each line is terminated with an end-of-line marker. You can declare and define such files as:
type
file-name = text;
Difference between a normal file of characters and a text file is that a text file is divided into lines, each terminated by a special end-of-line marker, automatically inserted by the system. The following example creates and writes into a text file named contact.txt:
program exText;
   filename, data:ShortString;
   myfile: text;
   writeln('Enter the file name: ');
   readln(filename);
   AssignFile(myfile, filename);
   rewrite(myfile);
   writeln(myfile,'Note to Students: ');
   writeln(myfile,'For details information on Pascal Programming');
   writeln(myfile,'Contact: Tutorials Point');
   writeln('Completed writing');
   closeFile(myfile);
end.
contact.txt
Completed writing
5. Appending to a File
Appending to a file means writing to an existing file that already has some data without overwriting the file. The following program illustrates this:
program exAppendfile;
   myfile: text;
   info:ShortString;
   assignFile(myfile,'contact.txt');
   append(myfile);
   writeln('Contact Details');
   writeln('dddd street');
   closeFile(myfile);
   //let us read fromthis file
   AssignFile(myfile,'contact.txt');
   reset(myfile);
   while not eof(myfile) do
      readln(myfile, info);
      writeln(info);
   CloseFile(myfile);
end.
Contact Details
dddd street
Note to Students:
6. File Handling Functions
Free Pascal provides the following functions/procedures for file handling:
S.NFunction Name & Description
1 procedure Append( var t: Text );
Open a file in append mode
2 procedure AssignFile( out f: file; const Name: );
Assign a name to a file
3 procedure AssignFile( out f: file; p: PChar );
4 procedure AssignFile( out f: file; c: Char );
5 procedure AssignFile( out f: TypedFile; const Name: );
6 procedure AssignFile( out f: TypedFile; p: PChar );
7 procedure AssignFile( out f: TypedFile; c: Char );
8 procedure AssignFile( out t: Text; const s: );
9 procedure AssignFile( out t: Text; p: PChar );
10 procedure AssignFile( out t: Text; c: Char );
11 procedure BlockRead( var f: file; var Buf; count: Int64; var Result: Int64 );
Read data from a file into memory
12 procedure BlockRead( var f: file; var Buf; count: LongInt; var Result: LongInt );
13 procedure BlockRead( var f: file; var Buf; count: Cardinal; var Result: Cardinal );
14 procedure BlockRead( var f: file; var Buf; count: Word; var Result: Word );
15 procedure BlockRead( var f: file; var Buf; count: Word; var Result: Integer );
16 procedure BlockRead( var f: file; var Buf; count: Int64 );
17 procedure BlockWrite( var f: file; const Buf; Count: Int64; var Result: Int64 );
Write data from memory to a file
18 procedure BlockWrite( var f: file; const Buf; Count: LongInt; var Result: LongInt );
19 procedure BlockWrite( var f: file; const Buf; Count: Cardinal; var Result: Cardinal );
20 procedure BlockWrite( var f: file; const Buf; Count: Word; var Result: Word );
21 procedure BlockWrite( var f: file; const Buf; Count: Word; var Result: Integer );
22 procedure BlockWrite( var f: file; const Buf; Count: LongInt );
23 procedure CloseFile( var f: file );
Close a file
24 procedure CloseFile( var t: Text );
Close a file
25 function EOF( var f: file ):Boolean;
Check for end of file
26 function EOF( var t: Text ):Boolean;
27 function EOF: Boolean;
28 function EOLn( var t: Text ):Boolean;
Check for end of line
29 function EOLn: Boolean;
30 procedure Erase( var f: file );
Delete file from disk
31 procedure Erase( var t: Text );
32 function FilePos( var f: file ):Int64;
Position in file
33 function FileSize( var f: file ):Int64;
Size of file
34 procedure Flush( var t: Text );
Write file buffers to disk
35 function IOResult: Word;
Return result of last file IO operation
36 procedure Read( var F: Text; Args: Arguments );
Read from file into variable
37 procedure Read( Args: Arguments );
38 procedure ReadLn( var F: Text; Args: Arguments );
Read from file into variable and goto next line
39 procedure ReadLn( Args: Arguments );
40 procedure Rename( var f: file; const s: );
Rename file on disk
41 procedure Rename( var f: file; p: PChar );
Rename file on disk
42 procedure Rename( var f: file; c: Char );
Rename file on disk
43 procedure Rename( var t: Text; const s: );
Rename file on disk
44 procedure Rename( var t: Text; p: PChar );
Rename file on disk
45 procedure Rename( var t: Text; c: Char );
Rename file on disk
46 procedure Reset( var f: file; l: LongInt );
Open file for reading
47 procedure Reset( var f: file );
48 procedure Reset( var f: TypedFile );
49 procedure Reset( var t: Text );
50 procedure Rewrite( var f: file; l: LongInt );
Open file for writing
51 procedure Rewrite( var f: file );
52 procedure Rewrite( var f: TypedFile );
53 procedure Rewrite( var t: Text );
54 procedure Seek( var f: file; Pos: Int64 );
Set file position
55 function SeekEOF( var t: Text ):Boolean;
Set file position to end of file
56 function SeekEOF: Boolean;
57 function SeekEOLn( var t: Text ):Boolean;
Set file position to end of line
58 function SeekEOLn: Boolean;
59 procedure SetTextBuf( var f: Text; var Buf );
Set size of file buffer
60 procedure SetTextBuf( var f: Text; var Buf; Size: SizeInt );
61 procedure Truncate( var F: file );
Truncate the file at position
62 procedure Write( Args: Arguments );
Write variable to file
63 procedure Write( var F: Text; Args: Arguments );
64 procedure Writeln( Args: Arguments );
Write variable to file and append newline
65 procedure WriteLn( var F: Text; Args: Arguments );
