Components and Libraries for HMI/SCADA applications, discussions, problems and suggestions
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6777
  • Andrea
  • Andrea's Avatar Topic Author
After update to codetyphon 5.2 I can't compile anymore my project, the error is:
unit1.pas(13,45) Fatal: Impossibile trovare HMIEdit usato da Unit1, ppu=C:\codetyphon\typhon\components\pl_PascalSCADA\lib\i386-win32\win32\hmiedit.ppu incompatibile, pacchetto pl_pascalscada
I don't know what to do, please someone can help me?
Andrea
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6778
  • Fabio Luis Girardi
  • Fabio Luis Girardi's Avatar
  • Thank you received: 13
Try recompile the pl_pascalscada package...
The following user(s) said Thank You: Andrea
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6781
  • Andrea
Thank you but just did it, now I will try to remove the component and then reinstal but I'm not to much confident that will solve the problem.
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6782
  • Andrea
I can confirm the problem. even after a clean up and rebuild of the component and reinstalled it the same message appear when I try to compile the project, of course with the 4.7 and 5.1 there are no problem.
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6787
  • Andrea
Please, there is a possibility to fix the problem?
Thank you.
Problem compiling project with CodeTyphon 5.2 11 years 5 months ago #6790
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
a big difference between 5.20 and the previous ones is... The FPC compiler itself (3.1.1 now, 2.7.1 before)
Did you clean all the .ppu/.o from your project folder ?
Try a full build and not only a compilation, I think you are reusing your "already-built" units.
Moderators: Curt
