TIdSSLIOHandlerSocketOpenSSL 13 years 6 months ago #2822
  • William
Wonder why there is no IdSSLIOHandlerSocketOpenSSL component in the Indy10 handle components? I can't seem to create a client that can make ssl connections. Any other way to create ssl connections? Thanks.
TIdSSLIOHandlerSocketOpenSSL 13 years 1 month ago #3692
  • 4aiman's Avatar
Bump!
I need it too!
The problem is TIdSSLIOHandlerSocketOpenSSL can be created in run time but it can't load ssl library.
For Windows there are 2 librares, mentioned at embarcadero delphi forums (as well as at stackoverflow), but for Linux there are no solution.
The only suggestion I found was to do this:
ssl:=TIdSSLIOHandlerSocketOpenSSL.Create(self);
     ssl.SSLOptions.Method:=sslvSSLv23;
     IdHTTP1.IOHandler:=ssl;
But this is not working!
TIdSSLIOHandlerSocketOpenSSL still can't find .so file despite BOTH of them (libssl.so and libcrypt.so) are in /usr/lib folder.
Moreover, running "openssl version" in terrminal gives me "OpenSSL 1.0.1 14 Mar 2012", but calling "showmessage(OpenSSLVersion);" returns an empty string :(
Sternas, please, check this...
(And please, check my win xp sp3 VS ct 4.2 thread...)
