× CodeTyphon Linux OS Development, discussions and problems
Question Scripts not executed
  • bernhard
  • Topic Author
  • Fresh Boarder
  • Fresh Boarder
4 months 2 weeks ago #11666 by bernhard
Scripts not executed was created by bernhard
Installed CTC latest version on UBUNTO
Most of the scripts are started but never completed the execution.
Strange effect observed : during OS shut down I see sudo request for user password input
4 months 2 weeks ago - 4 months 2 weeks ago #11667 by Sternas Stefanos
Replied by Sternas Stefanos on topic Scripts not executed
Please gives us more Info
1) Did you give "sudo" root privileges to installation user?
2) Did you install "System Libraries" ?
3) Your PC RAM etc. ?
For Ubuntu you can read:
this Ubuntu 18.04
or
this Ubuntu 17.10
Last edit: 4 months 2 weeks ago by Sternas Stefanos.
  • bernhard
  • Topic Author
  • Fresh Boarder
  • Fresh Boarder
4 months 2 weeks ago - 4 months 2 weeks ago #11668 by bernhard
Replied by bernhard on topic Scripts not executed
thanks for quick response
a) did "username ALL=(ALL) NOPASSWD: ALL" in sudo config , also followed instructions here : askubuntu.com/questions/91598/how-do-i-login-as-root
b) done during CTC setup , can use CTC IDE ... did some simple tests under LINUX/UBUNTU
c) 3 GBYTE RAM using VM ware , host is WIN 7 x64
Last edit: 4 months 2 weeks ago by bernhard.
4 months 2 weeks ago - 4 months 2 weeks ago #11670 by Sternas Stefanos
---1
NOT "username ALL=(ALL) NOPASSWD: ALL"
"username" is the login name to your OS
"login-name ALL=(ALL) NOPASSWD: ALL"
like
"sternas ALL=(ALL) NOPASSWD: ALL"
"muto ALL=(ALL) NOPASSWD: ALL"
"crazyhourse ALL=(ALL) NOPASSWD: ALL"
---- 2
To build Build-IDE 64bit you want RAM >=6Gbytes
To build Build-IDE 32bit you want RAM >=2Gbytes
To build Small-IDE 32 or 64bit you want RAM >=0.5Gbytes
