[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3516
  • Thank you received: 1132
We test CodeTyphon Lab ver 4.20
on new OpenSuse ver 12.3 (32 and 64 bits)
Tests list:
1)CT System libraries installation
2)CT Installation
3)CT Build All procedure
3)CT Update procedure
4)CT ToolChains download procedure
5)FreePascal compiler tests
6)Lazarus IDE tests
7)CodeOcean samples tests
8)Build some FPC crossbuild elements (jvm-android give error, arm-android it's OK)
Some screen from our lab tests:
first pic is from Suse Graphical sudo app (to give to user "sternas" sudo root privilege)
CT libraries in other pics
pl_GlassDocking,
pl_AGG,
pl_ORCA
pl_BGRAbitmap
pl_PascalScript
etc...
[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3518
  • ExDatis
  • ExDatis's Avatar
Perhaps it should be noted that version 12.3-32 has small problems starting FTP server
(I tried with vsftp and pure-ftpd without success) if someone develops this kind of app ...
p.s. I've seen several posts on SuSe forum and I wrote some...
[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3519
My suggestion for develop Internet Server app is
to use CentOS or Scientific Linux
95% of Internet linux servers use CentOS
I will test tomorrow Suse 12.3 32 and FTP server
[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3522
  • ExDatis
  • ExDatis's Avatar
Maybe usefull(message from openSuSe forum):
The problem is somewhere in pam authorization. I had to switch to pure-ftp and comment out the pam authorization and uncomment unix authorization in the pure-ftp config and it works...
p.s. I didn't try
[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3523
Thanks Sir for your information
So, you build Linux FTP Server application with CodeTyphon ? :woohoo:
[LAB] CodeTyphon on OpenSuse 12.3 13 years 2 months ago #3525
  • ExDatis
  • ExDatis's Avatar
Yes, Sir, I use FTP to store DICOM images and PostgreSQL database references that down. That allows to store all records for later use, and finding the right per patient.
Thanks for the interest.
p.s. Also, I have full confidence in use of openSUSE(have srv more then 7 years, works perfectly).
Last edit: by ExDatis.
