fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5640
  • trashtong
  • trashtong's Avatar Topic Author
when i try to "typhon32 IDE, BigIDE" or "SmallIde"
error with compiling fcllaz.pas.
i found a topic about this error. but it doesn't better. ( www.pilotlogic.com/sitejoom/index.php/fo...all-to-win7-x86#5575 )
even i delete c:\codetyphon folder before build typhon.
i used CT until ver4.8 with no problem.
is there anybody know how to solve this problem...?
i tried on win7-32bit
log
Compile Typhon Win32
C:/codetyphon/fpc/bin/i386-win32/make -C packager/registration
make[1]: Entering directory `C:/codetyphon/typhon/packager/registration'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f ../units/i386-win32/fcllaz.ppu
C:/codetyphon/fpc/bin/i386-win32/ppc386.exe -MObjFPC -Scghi -O1 -g -gl -vewnhi -l -Fu. -Fu../../../fpcsrc/rtl -FE. -FU../units/i386-win32 -g- -di386 fcllaz.pas
Hint: Start of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Hint: End of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Free Pascal Compiler version 2.7.1 [2014/07/04] for i386
Target OS: Win32 for i386
Compiling fcllaz.pas
Fatal: Can't find unit system used by fcllaz
Fatal: Compilation aborted
make[1]: Leaving directory `C:/codetyphon/typhon/packager/registration'
make: *** [Registration] Error 2
[ERROR]: Typhon32 Small-IDE NOT Build
Build Typhon BIG-IDE for Win32
[ERROR]: Sorry, Typhon32 from Small-IDE NOT Build
Terminate Action at 2014-07-14 13:29:52
Total time: 00:02:48.734
ExitCode : 0
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5642
Please Sir, post ALL build log from CTCenter
this is the second Error we want the fist Error in Building procedure
The following user(s) said Thank You: trashtong
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5646
  • trashtong
thank for reply.
all build log is attached to file "ct4_9_build_ide_error.txt"
Last edit: by trashtong.
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5662
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
Hi trashtong,
in several location in your log we can read "sh: C:\Program: No such file or directory".
This one is commonly a problem of PATH and should be solved by the script you found in the other topic.
Don't try to build directly from CT, but from a command line started with admin rights.
Start the normal setup.bat from CodeTyphonIns and stop it when the menu appears.
Then create the little .bat, place it "C:\codetyphon"
Start a fresh cmd from the Start Menu with admin rights (Right-click on cmd, Start as Administrator)
Then start this little .bat
About the success of your install of CT 4.80, you surely have installed since some application (like GIT) containing elements perturbating the correct execution of the install script (in make)...
Note that it happens sometimes to antiviruses to destroy some CT installation exe, considered as viruses.
I have the case with Avast!, it can be solved by adding execptions on "C:\codetyphon" and "C:\CodeTyphonIns" before install
There is no reason for CT install script to access any file in "C:\Program Files" but such "PATH parasite" !
Hope this will help you ;)
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5663
it's windows permition problem
make[5]: *** [echotime] Error 127
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5686
  • trashtong
i have found"sh.exe" is at C:\Program Files\Git\git-cheetah\..\bin and this directory included $PATH. ("cmd"->"where sh")
so i have open cmd as admin, then remove this directory from $PATH.
execute setup.bat -> remove all build all.
I do not know the results yet.
The build process takes long time.
i think it will be ok. i'll post again after build.
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5687
  • trashtong
it successfully finish.
thanks to sternas,Tony_O_Gallos. :woohoo:
[FINAL INFO]: Typhon32 BIG-IDE Build OK !!! Have fun.
[INFO]: Skip 64bit actions, this is 32 bits system...
CodeTyphon Studio 4.90 Setup for Windows32
Settings: Platform=Win32 Multiarch Mode=0
fcllaz.pas fatal error while i build typhonIDE 12 years 4 months ago #5688
Thanks Sir, have fun
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5976
  • mtbf40
  • mtbf40's Avatar
i have the same issue ... view attachment - CT Version 5.0
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5979
  • Steven
  • Steven's Avatar
Could you try this one.
Please let's have a try (and of course, run it as admin ;) )
@echo off
@set path=c:\codetyphon;c:\codetyphon\fpc\bin\i386-win32
c:
cd c:\codetyphon\
c:\codetyphon\setup.bat
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5980
  • mtbf40
  • mtbf40's Avatar
thanks,
a can't understand who is the context between CT and Git - i had Git installed and after remove CT could be installed :S
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5981
  • Tony_O_Gallos
Hi mtbf40,
it is a matter of environment and relative path in the installation process and make.
Executables are searched in path, and the first one with the proper name found in the list of directories will be used.
GIT contains sh.exe or rm.exe for example.
Some utilities using path relative from the executable could fail.
Either you can use the little script (originaly found here www.pilotlogic.com/sitejoom/index.php/fo...all-to-win7-x86#5575 )
or you can directly add "c:\codetyphon;c:\codetyphon\fpc\bin\i386-win32" or "c:\codetyphon;c:\codetyphon\fpc\bin\x86_64-win64" in front of you path environment of Windows to make CodeTyphon's directories visit first ;)
P.S.: As this is a recurrent problem, maybe it could be pinned in the forum ? :whistle:
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5984
  • Maximiliano
  • Maximiliano's Avatar
I have a same problem, and can't resolve this.
I remove gits, tortoise, and others but i can't build de IDE.
Win7 64bits.
Help please.
C:/codetyphon/fpc/bin/x86_64-win64/make -C packager/registration
c:/codetyphon/fpc/bin/i386-win32/rm.exe -f ../units/i386-win32/fcllaz.ppu
c:/codetyphon/fpc/bin/i386-win32/ppc386.exe -MObjFPC -Scghi -O1 -g -gl -vewnhi -
Free Pascal Compiler version 2.7.1 [2014/09/05] for i386
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5985
Typhon don't find FPC units
User has Administrator Privileges ?
Please build only FPC64 with CTCenter , zip and post here the Build-Log file info
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5990
  • Maximiliano
Yes i use Administrator Privileges
How do I do this?
CtCenter 64bits->FreePascal->FCP 64bits Build compiler. Is correct?
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5991
at logbuildall.zip
Line 20535: c:/codetyphon/fpc/bin/i386-win32/mv.exe: cannot remove `ppc386.exe': Permission denied
Line 20564: cp.exe: cannot remove old link to `ppc386.exe': Permission denied
etc
please look here for more help
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5993
  • Maximiliano
i try again creating a shortcut with Administrator Privileges as mentioned.
1. Prior to that reestablished privileges:
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
2. After desctivar access control windows.
3. Run as administrator CT
4. rebuild All
But...there is always one
the library zlib1.dll is corrupted, and and I've seen, that does not find other libraries
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5994
Sir On Win7 64
the CT installation is very simple
a)-Install system libraries info here
b)-log in in Windows as user with Administrator Privileges info
c)-Remove any previews Lazarus and FreePascal Installations
Now:
1)-Remove manual C:\codetyphon directory
2) unzip in any place CodeTyphonIns.zip
3)-Go to new CodeTyphonIns directory
4)-Simple double click on install.bat, not as Administrator etc
if this NOT work, please check your PATH files, your PC Configuration, Antivirus etc
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5996
  • Tony_O_Gallos
Hi maxid,
Did you do anything like I suggested ? (modification of path ?)
As I can see in your log rm.exe is called only through 32bit version...
It should be C:/codetyphon/fpc/bin/x86_64-win64/rm.exe instead of c:/codetyphon/fpc/bin/i386-win32/rm.exe
Please try c:\codetyphon;c:\codetyphon\fpc\bin\x86_64-win64 as your OS is 64bit ;)
(See here for example www.pilotlogic.com/sitejoom/index.php/fo...mpile-codetyphon-4-8 )
:whistle: Your logbuildall
Compile Typhon Win64
c:/codetyphon/fpc/bin/i386-win32/ppc386.exe -MObjFPC -Scghi -O1 -g -gl -vewnhi -l -Fu. -Fu../../../fpcsrc/rtl -FE. -FU../units/i386-win32 -g- -di386 fcllaz.pas
fcllaz.pas fatal error while i build typhonIDE 12 years 2 months ago #5997
  • Maximiliano
Using CT since version 3 installation never failed me so far.
  1. I tried putting in the path to start.
  2. Run install.bat as administrator and non-administrator.
  3. Remove the antivirus.
  4. Remove access control.
  5. 64bit Windows if
  6. I did everything and just fails.
Demoniac, Win7!!!!
Uso CT desde la version 3, nunca me falló la instalación hasta ahora.
Probé poneindo en el path al comienzo.
Ejecutar install.bat como administrador y no administrador.
Quitar el antivirus.
Quitar el control de acceso.
Windows si es de 64bits
hice todo e igual falla. Maldito Win7.
