Can not find unit system used by fcllaz of package 13 years 3 weeks ago #3865
  • Richard Maley
  • Richard Maley's Avatar Topic Author
I am trying to build my first app with CodeTyphon.
I am following the video example found at
I am working on a Windows 7 machine. I am trying to compile for linux and arm.
When I build the app I get the following error:
fcllaz.pas(0,0) Fatal: Can not find unit system used by fcllaz of package FCL.
Any ideas on how I fix this?
Dick Maley
Can not find unit system used by fcllaz of package 13 years 2 weeks ago #3953
  • PiSymbol
  • PiSymbol's Avatar
I'm having the same troubles. I've installed CodeTyphon successful. I'd like to start developing Android Phone applications.
Take the following steps to reproduce:
- Run Lazarus32
- Create new project ('Project' -> 'New Project' -> 'Application')
- Go to menu 'Project' -> 'Project Options' -> 'Code Generation' -> 'Target OS (-T) = android' AND 'Target CPU Family (-P) = arm'
- Build the Project
The error message is: fcllaz.pas(0,0) Fatal: Can not find unit system used by fcllaz of package FCL.
What actions should I take?
Thank you in advance for your response.
Can not find unit system used by fcllaz of package 13 years 2 weeks ago #3954
  • Thank you received: 1132
Please wait for ver 4.30
we solve this problem
Can not find unit system used by fcllaz of package 13 years 2 weeks ago #3958
  • PiSymbol
  • PiSymbol's Avatar
Thank you for your response. I'll wait until the next version.
Can not find unit system used by fcllaz of package 13 years 4 days ago #4104
  • Svenn
  • Svenn's Avatar
I have installed 4.30 and see the same error message when trying to build the androidlcl example.
I have corrected the path setting in the project according to the tutorial on the CodeTyphon homepage.
Other CT projects for win32 platform that I wrote for CT4.20 works.
I wiped old CT4.20 before installing CT4.30 from scratch from zip.
I run CT4.30 on win7 x64
Can not find unit system used by fcllaz of package 13 years 4 days ago #4105
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
change target os "Linux arm" to "Android arm"
Cross-Build for Android Help:
www.pilotlogic.com/sitejoom/index.php/wi...ss-build-for-android
windows xp 32: help sternas:
Guys your help
We update FreePascal SVN 06-06-2013 Rev 24810
1) Download files:
www.pilotlogic.com/codetyphon/dev/fpc_src_make.7z
www.pilotlogic.com/codetyphon/dev/fpc_src_mod.7z
www.pilotlogic.com/codetyphon/dev/fpc_src.7z
2)Replace files at: "codetyphon\allzips\src" folder of CodeTyphon ver 4.30
3)"Remove and Build ALL" (FPC, Typhon etc)
and please report here
www.pilotlogic.com/sitejoom/index.php/fo...tabase-desktop-error
Can not find unit system used by fcllaz of package 12 years 11 months ago #4227
  • Gadi D
  • Gadi D's Avatar
Hi All
I am using CT 4.30 on Windows 7 64Bit, I am also got "Can not find unit system used by fcllaz of package"
I did all steps and still the same problem , can't port to android
Any Idea please?
Best Regards
Gadi
