Installation of CT4 fails on Win7 x64 13 years 9 months ago #3306
  • Noel
  • Noel's Avatar Topic Author
Running Remove and Build All in CT Center, installation fails on Windows 7, 64-bit. The following is an extract from the CommandBox tab.
Target OS: Win64 for x64
Compiling fcllaz.pas
Fatal: Can't find unit system used by fcllaz
Fatal: Compilation aborted
make[1]: Leaving directory `C:/codetyphon/lazarus/packager/registration'
make: *** [Registration] Error 2
I have tried running setup.bat from an elevated command prompt but it also fails. I can't tell what error messages are returned as the batch file exits and closes my command prompt. Please can you change this, as it makes it impossible to tell what errors have occured. Anyway, if a user opens a command prompt, it really should not be closed until the user chooses to close it. If you need the batch file to exit automatically under certain circumstances, then you could possibly set and subsequently test an environment variable to see if EXIT should be executed or not.
Last edit: by Noel.
Installation of CT4 fails on Win7 x64 13 years 8 months ago #3438
  • Noel
Seeing as I've had no response, I thought I'd dig around a little more. It appears that FP's make has problems. I've tried updating make.exe to the latest version of mingw make, but the problem persists. This happens when the 32-bit compiler is being built.
                 Clean FreePascal 32bit
C:/codetyphon/fpc/bin/i386-win32/make -C compiler distclean
make[1]: Entering directory `C:/codetyphon/fpcsrc/compiler'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f ppcross386.exe ppc.exe ppc1.exe ppc2.exe ppc3.exe ./msg2inc.exe pp1.wpo pp2.wpo
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f ppc386.exe ppc68k.exe ppcx64.exe ppcppc.exe ppcsparc.exe ppcppc64.exe ppcarm.exe ppcmips.exe ppcmipsel.exe ppcjvm.exe ppc386.exe ppcwpo1.exe ppcwpo2.exe
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f pp.exe pp.o libppp.a libimppp.a
C:/codetyphon/fpc/bin/i386-win32/rm.exe -rf units
C:/codetyphon/fpc/bin/i386-win32/make: Interrupt/Exception caught (code = 0xc0000005, addr = 0x74C943F9)
make: *** [compiler_distclean] Error 255
Attempting to build Freepascal 64-bit brings up a dialog informing me of a missing dependency for make.exe - libintl-8.dll
Last edit: by Noel.
Installation of CT4 fails on Win7 x64 13 years 8 months ago #3440
  • Noel
Digging a bit deeper, I have found that the version of make used has problems if the PATH variable contains round brackets (). Temporarily removing anything in the path that contains round brackets allowed the FPC/Lazarus build to proceed. I suspect that the problem with the round brackets in the PATH variable will cause Lazarus to fail to make projects though.
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4058
  • vmakre
  • vmakre's Avatar
When i try to install CT 4.3 on Windows 7 64 bit
after start.bat and Clean and Build all , i found error in
batch scripts running make with error 255 .
In CodeTyphon Center after 'FPC Extract source' and 'FPC build Compiler'
showing strange error in make some error 255.
I tried with removing braces as from previous post but no luck.
After some researching i found possible solution
downloading new make.exe for both 32 and 64 bit from 'www.equation.com/servlet/equation.cmd?fa=make' and copy them
in C:\codetyphon\fpc\bin\i386-win32\ and C:\codetyphon\fpc\bin\x86_64-win64\ accordingly.
I think this is easy fixable bug but was very annoying and should be resolved in next upgrade.
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4060
Please Sir
zip and post make files for test
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4061
  • opc0de
  • opc0de's Avatar
Check your path It might already contain a fpc/ codetyphoon install remove it and then try again!
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4066
  • vmakre
  • vmakre's Avatar
Building CT 4.3 on Win 7 64 bit and Win XP 32 bit.
Again i have difficulties with building Typhoon Small IDE 32 bit, but also other builds.
FPC is building fine but error with fcllaz.ppu breaks process when i try 'Typhon32 Build Small IDE'.
This is same error and breaks on two computers Win 7 64 bit , and Win XP sp3.
All two machines had Lazarus installed before but everything is removed , folders, registry and path variables.
if I'm wrong on something suggestions are welcome ...
[INFO]: Clean finish...
[FINAL INFO]: FreePascal 32 Building, finish...
            Prepare Typhon Win32
 Typhon32 Restore Default Settings for Windows
..\binSettings\settings\i386-win32-win32\styphon\editoroptions.xml
..\binSettings\settings\i386-win32-win32\styphon\environmentoptions.xml
..\binSettings\settings\i386-win32-win32\styphon\h2pastool.xml
..\binSettings\settings\i386-win32-win32\styphon\inputhistory.xml
..\binSettings\settings\i386-win32-win32\styphon\lazarus.dci
..\binSettings\settings\i386-win32-win32\styphon\miscellaneousoptions.xml
..\binSettings\settings\i386-win32-win32\styphon\packagefiles.xml
7 File(s) copied
 Typhon64 Restore Default Settings for Windows
..\binSettings\settings\x86_64-win64-win32\styphon\editoroptions.xml
..\binSettings\settings\x86_64-win64-win32\styphon\environmentoptions.xml
..\binSettings\settings\x86_64-win64-win32\styphon\h2pastool.xml
..\binSettings\settings\x86_64-win64-win32\styphon\inputhistory.xml
..\binSettings\settings\x86_64-win64-win32\styphon\lazarus.dci
..\binSettings\settings\x86_64-win64-win32\styphon\miscellaneousoptions.xml
..\binSettings\settings\x86_64-win64-win32\styphon\packagefiles.xml
7 File(s) copied
            Compile Typhon Win32
C:/codetyphon/fpc/bin/i386-win32/make -C packager/registration
make[1]: Entering directory `C:/codetyphon/typhon/packager/registration'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f ../units/i386-win32/fcllaz.ppu
C:/codetyphon/fpc/bin/i386-win32/ppc386.exe -MObjFPC -Scghi -O1 -g -gl -vewnhi -l -Fu. -FE. -FU../units/i386-win32 -g- -di386 fcllaz.pas
Hint: Start of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Hint: End of reading config file C:\codetyphon\fpc\bin\i386-win32\fpc.cfg
Free Pascal Compiler version 2.7.1 [2013/06/02] for i386
Copyright (c) 1993-2013 by Florian Klaempfl and others
Target OS: Win32 for i386
make[1]: Leaving directory `C:/codetyphon/typhon/packager/registration'
[ERROR]: Typhon32 Small-IDE NOT Build
The following user(s) said Thank You: Alfred
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4067
  • Marius
  • Marius's Avatar
You don't have enough ram.
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4069
  • vmakre
  • vmakre's Avatar
Finally problem SOLVED :woohoo:
I found
sh: C:\Program: No such file or directory
in log , so this shows that something is going to C:\program files\ folder.
I had Git installed in 'C:\program files\git' and found in environment path
variable 'C:\Program Files\Git\bin' and also some exe files needed by compiler
executed from Git folder. I simply renamed 'Git' folder to example 'Git-old' and
now i have Typhon32 for Win32 ready.
I think we need some good PATH strings to put in OS Environment path variables but
i am not sure which folders and paths for CodeTyphon , and also what happens when we have two different path variables with same exe files inside.
The following user(s) said Thank You: Jose Torres
Installation of CT4 fails on Win7 x64 13 years 5 months ago #4075
  • Vladimir Bazović
  • Vladimir Bazović's Avatar
  • Thank you received: 4
This is a problem for all Win platforms, if you have something in path that overrides CT's commands as sh, cp ... installation will fail. For me problematic commands were from Gow (Gnu on Windows). Solution is simply to delete this paths from environment variable. You can return it after installation, for me ls,tail, grep are indispensable.
And in the future perhaps CT could have absolute paths to commands?
The following user(s) said Thank You: Jose Torres, ExDatis
Installation of CT4 fails on Win7 x64 12 years 4 months ago #5735
  • Alfred
  • Alfred's Avatar
  • -- > Who blind your eyes, steal your dreams
Hello all.
I have the same problem and I can not solve. No just found the problem. Win64. CT 4.92, ... 4.50
Kind soul that returns me the good mood?
PATH has a reference to a usb drive disconnected (K: gnupg / pub)
Thanks.
A.R.
Installation of CT4 fails on Win7 x64 12 years 4 months ago #5739
Sir, in FPC build procedure cp.exe don't have the Permission to copy/move files
did you have administrator Permissions in your PC ?
please read more here
C:/codetyphon/fpcsrc/compiler/ppc2.exe and C:/codetyphon/fpcsrc/compiler/ppc3.exe are equal
C:/codetyphon/fpc/bin/x86_64-win64/cp.exe -fp C:/codetyphon/fpcsrc/compiler/ppc3.exe ppcx64.exe
cp.exe: cannot remove old link to `ppcx64.exe': Permission denied
make[3]: *** [next] Error 1
make[3]: Leaving directory `C:/codetyphon/fpcsrc/compiler'
make[2]: *** [cycle] Error 2
make[2]: Leaving directory `C:/codetyphon/fpcsrc/compiler'
make[1]: *** [compiler_cycle] Error 2
make[1]: Leaving directory `C:/codetyphon/fpcsrc'
make: *** [build-stamp.x86_64-win64] Error 2
Installation of CT4 fails on Win7 x64 12 years 4 months ago #5741
  • Alfred
  • Alfred's Avatar
Oh, thank you.
Your karma is more positive than before.
My age starts to play tricks
A.R.
Installation of CT4 fails on Win7 x64 12 years 4 months ago #5742
Thanks Sir, have fun
oh and my age too... :unsure:
PS:my Italian: Lancia Kappa 20v Turbo
