Error d3d9.dll 13 years 11 months ago #2613
  • CGB
  • CGB's Avatar Topic Author
when you want to install 2.9 on winXP 32bit and want to use the BIdIDE generates an error directx d3d9.dll dll. why this happens?
Error d3d9.dll 13 years 11 months ago #2616
  • Serge Lebedev
  • Serge Lebedev's Avatar
This happens because a principal incompatibility a component pl_win_directx11 with Windows'XP available DirectX.
If you want to start BigIde from 2.90 on XP, you must manually remove package pl_win_directx11 and pl_AsphyreSphinx & pl_ORCA (contain directx11 package depending code).
from /bin/src/lazarus_mod_src.zip
from /lazarus/components - Makefile & Makefile.fpc
from /lazarus/ide - Makefile & Makefile.fpc & lazarus.pp
- please remove all strings with problem packages info
from /lazarus/packager/globallinks - remove links to problem packages
from /bin/settings/win32/slazarus:
from miscellaneousoptions.xml & packagefiles.xml - remove xml parts, that describes a problem packages
from /scriptsWin/x_Lazarus_Win32_build.bat remove all strings, contains compilation form problem packages.
rebuild lazarus by std for CodeTyphon method.
