ORCA TD2Background doesn't fire OnBeforePaint evnt 13 years 1 month ago #3793
  • RockyLuck
  • RockyLuck's Avatar Topic Author
TD2Background does have an OnBeforePaint event like any other TD2VisualObject. However, because of the way this works, the top TD2Backround (the root) does not fire this event. That's a pity, because it's an ideal place to initialize some components at run time, if that's not possible at design time.
The reason OnBeforePaint event is not fired is because that event is fired only for all the children of a given object. Since the root object (TD2Background) is not a child of any object, the OnBeforePaint is never called.
The following patch remedies this omission.
In orca_scene2d.pas inherit the BeforePaint method in TD2Background
TD2Background = class(TD2Control)
  private
    FFill: TD2Brush;
    procedure SetFill(const Value: TD2Brush);
  protected
    procedure BeforePaint; override;            // *** DB ***
    procedure PaintChildren; override;
    procedure FillChanged(Sender: TObject); virtual;
  public
    constructor Create(AOwner: TComponent); override;
    destructor Destroy; override;
    procedure Paint; override;
  published
    property Resource;
    property Fill: TD2Brush read FFill write SetFill;
In orca_scene2d_obj_controls.inc make this little change:
procedure TD2Background.FillChanged(Sender: TObject);
  Repaint;
procedure TD2Background.BeforePaint;                  // *** DB ***
begin                                                 // *** DB ***
   inherited BeforePaint;                             // *** DB ***
   if Assigned(FOnBeforePaint) then begin             // *** DB ***
      // Only if we're the top background             // *** DB ***
      if Self.Scene.GetRoot = Self then               // *** DB ***
         FOnBeforePaint(Self, Self.Canvas,            // *** DB ***
                      d2Rect(0, 0, FWidth, FHeight) );// *** DB ***
   end{if};                                           // *** DB ***
end;                                                  // *** DB ***
ORCA TD2Background doesn't fire OnBeforePaint evnt 13 years 2 weeks ago #3900
  • Thank you received: 1132
Yes Sir
