× General Purpose Components and Libraries, discussions, problems and suggestions
Question OnGuard components error
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
8 months 3 weeks ago - 8 months 3 weeks ago #11064 by Nicola
OnGuard components error was created by Nicola
I'm testing pl_onguard with the sample "regdemo" in CodeOcean.
Using rgc.exe to generate the Release Code I get a code like this: BF2A D4C2 2D26 E9CF0000
but when I go into registration.exe I get the following error: "Invalid Serial Number. Please check your entry and try again."
With an old version of onguard I do not have this problem.
I use CT32 6.20 on windows 10
A tip?
Thank you
Last edit: 8 months 3 weeks ago by Nicola.
8 months 3 weeks ago #11065 by Sternas Stefanos
Replied by Sternas Stefanos on topic OnGuard components error
we will try to fix this
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
8 months 2 weeks ago #11067 by Nicola
Replied by Nicola on topic OnGuard components error
I'm confident.
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
7 months 3 days ago #11181 by Nicola
Hi Mr Sternas, is there any chance of seeing this problem fixed in version 6.40?
Thank you
7 months 2 days ago #11182 by Sternas Stefanos
please give us time to solve this problem
-Did you test CodeTyphon 6.30 ?
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
7 months 1 day ago #11185 by Nicola
Yes, I tested with CT 6.30 but I have the same error.
I attach the error.
7 months 1 day ago #11186 by Sternas Stefanos
please give us time to solve this problem..
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
7 months 22 hours ago #11190 by Nicola
Of course
6 months 4 weeks ago - 6 months 4 weeks ago #11196 by Sternas Stefanos
Finally ( I think) we fix the problem
One file with new pl_OnGuard 6.4.1 Library for Typhon IDE
and one file with new regdemo applications for CodeOcean
Please test, report and have fun... :)
Last edit: 6 months 4 weeks ago by Sternas Stefanos.
  • Nicola
  • Topic Author
  • Junior Boarder
  • Junior Boarder
6 months 4 weeks ago - 6 months 4 weeks ago #11197 by Nicola
Hi Mr. Sternas,
thanks for the speed of your answer.
I have tested the new version of onGuard.
I think, however, that you need to make small changes in the rcg_Main unit of the rcg.ctpr demo to work properly even when choosing an "Application Key" other than the default one.
The event to be changed is spdReleaseCodeClick which will be modified as follows
procedure TrcgMain.spdReleaseCodeClick(Sender: TObject);
  Modifier : longint;
  SerialNum : longint;
  Expires : TDateTime;
  ReleaseCode : TCode;
  CodeString : string;
  edtReleaseCode.Text := '';
  // Get the key that will be used to generate the ReleaseCode
  fKey := ApplicationKey;
  if chkMachMod.Checked then
    try
      Modifier := StrToInt(edtMachineMod.Text);       <<============ Enable
      ApplyModifierToKeyPrim(Modifier, fKey, sizeof(fKey));       <<=== Enable
 //      fKey:=MachineKey;                                        <<============ Disable
    except
      MessageDlg('Invalid Machine Modifier.  Please check your entry and try again.', mtError, [mbOK], 0);
      exit;
  // Get the expiration date
  if chkExpires.Checked then
    try
      Expires := StrToDate(edtExpires.Text);
    except
      MessageDlg('Invalid Expiration Date.  Please check your entry and try again.', mtError, [mbOK], 0);
      exit;
    end
  else
    Expires := 0;
  // Get the serial number
  try
    SerialNum := StrToInt(edtSerialNumber.Text);
  except
    MessageDlg('Invalid Serial Number.  Please check your entry and try again.', mtError, [mbOK], 0);
    exit;
  // Create the release code for the data givien
  InitSerialNumberCode(fKey, SerialNum, Expires, ReleaseCode);
  CodeString := BufferToHex(ReleaseCode, sizeof(ReleaseCode));
  // Insert spaces in the release code string for easier reading
  System.Insert(' ', CodeString, 17);          <<===================== Add
  System.Insert(' ', CodeString, 13);
  System.Insert(' ', CodeString, 09);
  System.Insert(' ', CodeString, 05);
  edtReleaseCode.Text := CodeString;
Thanks again for your great work
Last edit: 6 months 4 weeks ago by Nicola.
6 months 4 weeks ago #11198 by Sternas Stefanos
we will add your suggestions to CodeOcean
